Speedo calibration - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gasco, this thread has received 5 replies and been viewed 952 times.
post #1 of 6 (permalink) Old 12-20-2006, 04:52 PM Thread Starter
Speedo calibration
I have an 05 Excursion w/ Edge Juice w/ Attitude. I run 37's in summer, and 35's in winter. I really need to calibrate my tires to the speedo, and my early release Edge programmer won't do it. Is there a cheap and easy way to correct this?
gasco is offline
post #2 of 6 (permalink) Old 12-20-2006, 05:24 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
You can get your speedo calibrated for up to a 35" tire at your dealer but anything bigger you have to get a truspeed
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 6 (permalink) Old 12-20-2006, 09:55 PM
or you can get rid of the edge before it smokes your tranny and buy an SCT that not only will be easier on your trans but you can adjust for tire size too.
FIREBALL is offline
post #4 of 6 (permalink) Old 12-21-2006, 12:25 AM
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
SCT will not adjust the speedo. It will work only on the tranny shifts when using the adjusted tire size.
HeavyAssault is offline
post #5 of 6 (permalink) Old 12-21-2006, 12:27 AM Thread Starter
why is the edge hard on trannys? Anything other than truespeed?
gasco is offline
post #6 of 6 (permalink) Old 12-21-2006, 12:29 AM
Yes, the SCT xcal2 will recalibrate the ecm for different tire sizes and it will up the trans pressure for firmer shifts and is user adjustable for shift points and other perameters.
FIREBALL is offline
