Air Horn where to mount? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2towrjp, this thread has received 15 replies and been viewed 1129 times.
post #1 of 16 (permalink) Old 12-21-2006, 02:21 PM Thread Starter
whistling up a storm
I just received my WOLO powerhouse 418 Air horn. Although Nathans would have been better, I couldn't justify the cost. anyhoo...
Where are you guys mounting your air horns? there is no room under the hood. I started to remove the fender to place where original is, but that is just too much hassle if I need to troubleshoot later.
Thanks guys. Trying to knock this out today, as we leave for FL tomorrow.
'03 PSD 6.0 CCSB 4x4 Lariat loaded-no moon or pedals. SCT XCAL2 by LIPD/DP-Tuner CORRECTED BY RYAN @ SCT
DR EDGE 4.5 with signature shocks, HELO MAXX 8's on 325/65/18 Nitto TG's, 4" MBRP 409 SS turboback w/ powertube, cat delete, and 6" tip, AEM brute force intake, Sinister EGR Valve/Cooler Delete and Coolant Bypass Filter, Y-PIPE, Upipe upgrades, Overhead ISSPRO EV2 GUAGEs (4), Tint, ventvisor, rockford fosgate/XM, Vector bedliner.
MODS: blockheater lic plate, AIC, steveracer, Harpoon, zoodad, flipped cc seat brackets.
To Do list:CCV Reroute
Wishlist: power rear seat, power rear slider or Sleeper cab
2towrjp is offline
post #2 of 16 (permalink) Old 12-21-2006, 02:37 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
I have train horns mounted on the frame rail under the drivers seat. Some people mount them on the frame or behind the front bumper...
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 16 (permalink) Old 12-21-2006, 02:49 PM
is here and there.
Rcannon's Avatar
Images: 11
I sure like the price of those versus Nathans
Rcannon is offline
post #4 of 16 (permalink) Old 12-21-2006, 03:04 PM Thread Starter
I was just reading the install in the mods section. nice work.
2towrjp is offline
post #5 of 16 (permalink) Old 12-21-2006, 03:51 PM Thread Starter
read this in the write up:
"FYI...There is a positive polarity horn wire (yellow with green tracer) behind the fuse box"
anyone know where the loom is that carries this to the horn? I plan to splice into this line, but do not want to take the fender off the access the actual connection/horn.
Thanks
2towrjp is offline
post #6 of 16 (permalink) Old 12-21-2006, 04:03 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
on Page 4 it shows a pic..
post #7 of 16 (permalink) Old 12-21-2006, 04:06 PM Thread Starter
I mean further down the wire run. The quote I snagged was from that pic.
I found a yellow with green tracer, but it is about 10 guage, located with a splitter next to the blower motor on the pass side. Can't find that 16 guage line.
EDit...
Found it, there is no power to it, (ground activated) put a test lamp on it, pressed the horn, wha-lah.
Tahnks again HH, you seem to answer all of my questions.
2towrjp is offline
post #8 of 16 (permalink) Old 12-21-2006, 04:14 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
only one and it is on the passenger side inner fender
post #9 of 16 (permalink) Old 12-21-2006, 04:57 PM Thread Starter
Going to go for a test drive, if there is noticable delay while the compressor builds, I will cut the rest of that line going to the OEM horn. (reason I was asking if there were one or two horns)
2towrjp is offline
post #10 of 16 (permalink) Old 12-21-2006, 07:36 PM Thread Starter
Sounds good. nice deep tone, not too loud. well worth the $45.
2towrjp is offline
