Question about a noise. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4wydnr, this thread has received 4 replies and been viewed 424 times.
post #1 of 5 (permalink) Old 12-21-2006, 05:45 PM Thread Starter
I recently installed the superchips tuner in my truck with a 4" MBRP exhaust with no muffler or cat. When I floor it there is an odd chattering sound that seems to be coming for the top of the engine. Any clues on what could cause this? I'm wondering if it has something to do with the stock intake and standard filter, but the vacuum gauge on the airbox doesn't show any extra pull. Or is it something in the valvetrain? Any ideas would be greatly appreciated.
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 Dana 80
4wydnr is offline
post #2 of 5 (permalink) Old 12-21-2006, 05:50 PM
CSIPSD's Avatar
Most likely surge, Wicked Wheel, ATS housing, or a differant exhaust housing will help or stop it. It will get worse with a Hi flow intake. Could, and I say could be something with the EBPV... But that is unlikely.
CSIPSD is offline
post #3 of 5 (permalink) Old 12-21-2006, 05:57 PM Thread Starter
I should mention a code was coming up for the waste gate failing a steady state test. I'm not sure if this was coming up before the chip or not.
4wydnr is offline
post #4 of 5 (permalink) Old 12-21-2006, 06:59 PM
Supporting Vendor
Do you here the noise at around 1800 rpm or is it just when your flooring it you hear it the entire time?
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #5 of 5 (permalink) Old 12-22-2006, 01:49 PM Thread Starter
It only makes the noise for a short time when I floor it but it does it mainly towards the top end of the RPM range ( around 2,400 to 3,000).
4wydnr is offline
