HELP! ABS Warning Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TowRig, this thread has received 3 replies and been viewed 902 times.
post #1 of 4 (permalink) Old 04-13-2007, 05:52 AM Thread Starter
Send a message via AIM to TowRig
My ABS warning light came on today while i was driving and then the tranny shifted out of overdrive almost instantly. What is the deal?
Thanks in advance
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #2 of 4 (permalink) Old 04-15-2007, 12:20 AM Thread Starter
Anyone?
AJ
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
post #3 of 4 (permalink) Old 04-15-2007, 03:37 PM
You could have a corroded ABS wire or sensor that could cause this. I just had a similar problem. When I threw a code it was causing my instrument cluster to completely shut down, or sometimes all my guage needles would frantically dance around. I was still under warranty, so I don't know about cost to cure.
imported_DieselFord05 is offline
post #4 of 4 (permalink) Old 04-15-2007, 07:37 PM Thread Starter
Thanks
AJ
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
