Rear End Fluid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fuzzys69, this thread has received 5 replies and been viewed 712 times.
post #1 of 6 (permalink) Old 02-01-2008, 03:38 AM Thread Starter
fuzzys69's Avatar
Rear End Fluid
Im going to be changing my rearend fluid in a few week, what kind should i use? and how much? I was looking at royal purple since they already have the additive for the Limited Slip. what weight is good to use?
Thanks Fuzzy
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #2 of 6 (permalink) Old 02-01-2008, 08:28 AM
75-140 synthetic is what Ford says. I would go with Royal Purple also, at GI Joes it is the same price as the walmart brand oil(like $9.75 qt). I believe it is about 3.5qts total. Wear gloves, that stuff stinks bad!
'99 F-350 Supercab Lariat built 2/13/99
Camper Package, TS 6-pos chip, DIY Tymar, 4" Magnaflow turboback SS Exhaust, 203* Thermostat, Coolant Filter, Upgraded Headlights/corner lamps, Custom center console with a sub
Autometer Guages were stolen!
MANUAL HUBS AND TRANSFER CASE!
mrit is offline
post #3 of 6 (permalink) Old 02-01-2008, 01:12 PM
FILTERS
Amsoil Oil Filter....EAO11
Wix Oil Filter.......51372
Oil Vapor Filter.....N/R
Amsoil Air Filter....EAA191
Wix Air Filter.......46418
Wix Fuel Filter......33296
Wix Trans Filter.....58968
Wix Cabin Filter.....24876
NGK PLUGS & WIRE SETS
IXIRIDIUM Plug......NGK3689 [1]
VPOWER Plug.........NGK4177 [2]
Wire Set............NGK58901 [3]
1. Plugs - SOHC
2. Plugs - SOHC
3. 8 CPBs Req'd
TRICO WIPER BLADES
Blade Class..|..Driver.....|..Passenger
Neoform.......|..T16200..|..T16200
Exactfit.........|..T201......|..T201
Winter..........|..T37205..|..T37205
Oktane.........|..20 inch...|..20 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
All Temps......5W-20 [1]
Manual Transmission,6-SPD ZF S6-650.....MA5
Synthetic Automatic Transmission Fluid
Automatic Transmission,5R110W.....MSP [2]
Differential, Front .....GL-5
All Temps......90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Standard Differential, Rear Dana 135.....GL-5 [3]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Controlled Slip Differential, Rear Dana 135.....GL-5* [3][4]
Severe Gear 75W-140
Standard Differential, Rear Dana 80.....GL-5 [5]
All Temps......75W-90
Severe Gear 75W-90
Severe Gear 75W-110
Controlled Slip Differential, Rear Dana 80.....GL-5* [5][6]
Severe Gear 75W-90
Standard Differential, Rear Ford.....GL-5 [7]
Severe Gear 75W-140
Controlled Slip Differential, Rear Ford.....GL-5* [7][8]
Severe Gear 75W-140
Standard Differential, Rear S110, S130.....GL-5 [9]
Severe Gear 75W-140
Transfer Case,.....MA
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Fluids
Power Steering Fluid.....MA5
Brake Fluid.....HBH
Clutch Fluid.....HBH
1. Use Ford part no. XO-5W20-QSP or equivalent motor oil meeting Ford specification WSS-M2C153-H.
2. Mercon-SP is not interchangeable W/ Mercon, Mercon-V or Mercon Synthetic.
3. Synthetic oil is required.
4. Add 8 oz of friction modifier Ford part no. C8AZ-19B546-A or equivalent meeting Ford Spec EST-M2C118-A for axle refill
5. Synthetic oil is required.
6. Add 8 oz of friction modifier Ford part no. C8AZ-19B546-A or equivalent meeting Ford Spec EST-M2C118-A for axle refill
7. Synthetic oil is required.
8. Add 8 oz of friction modifier Ford part no. C8AZ-19B546-A or equivalent meeting Ford Spec EST-M2C118-A for axle refill
9. Synthetic oil is required.
CHASSIS LUBRICATION
Two-wheel drive
4-10 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
0-7 Fittings, 0 Plugs..........LM
CAPACITIES
Engine, with filter..........6.0 quarts [1]
Cooling System, Initial Fill..........27.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4R100 Initial Fill..........6.5 quarts [2]
Automatic Transmission, 5R110W Initial Fill..........7.5 quarts [2]
Automatic Transmission, Total Fill
4 speed 20 plate 4R100..........17.0 quarts
4 speed 26 plate 4R100..........18.0 quarts
Manual Transmission, 6-SPD W/ OCOOL..........13.0 pints
Manual Transmission, 6-SPD W/O OCOOL..........12.0 pints
Manual Transmission, 5-SPD ZF..........6.8 pints
Differential, Dana 135 Rear..........31.0 pints
Differential, with 10.5 ring gear Rear..........7.0 pints
Differential, Dana 80 Rear..........8.4 pints
Differential, Dana 50 Front..........3.8 pints
Differential, Dana 60 Front..........5.7 pints
Transfer Case,..........4.0 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....10 ft-lbs
Transfer case NV271
Fill Plug.....20 ft-lbs
Drain Plug.....20 ft-lbs
Manual Transmission ZF S6-650
Fill Plug.....26 ft-lbs
Drain Plug.....26 ft-lbs
This Should help I think..
splitter is offline
post #4 of 6 (permalink) Old 02-01-2008, 01:18 PM
is here and there.
Rcannon's Avatar
Images: 11
nice list, but is that for a 6.0L?
reason I ask is this..
Rcannon is offline
post #5 of 6 (permalink) Old 02-01-2008, 01:22 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
No it is probably just a generic list that covers most fords.. diffs. are all the same though
2003 F250 "Pulling Truck"
hhrecovery is offline
post #6 of 6 (permalink) Old 02-03-2008, 04:01 AM Thread Starter
fuzzys69's Avatar
i want to double check that royal purple does already have limited slip additive in it. does anyone know this for sure?
SOLD!!
Singles Club #30
B.O.M.B. Squad #11
fuzzys69 is offline
