transfer case - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by indyF-350psd, this thread has received 2 replies and been viewed 624 times.
post #1 of 3 (permalink) Old 04-11-2008, 05:52 PM Thread Starter
transfer case
the book says to use mercon when changing the transfer case fluid but never says the capacity. anyone know how much i need for my F350? and does anyone in the midwest use anything else other than standard mercon atf fluid? i was reading the lucas 80-90w gear oil bottle and it said its perfect for transfer cases but i thought it might get too thick in the winter time here in indy. any thoughts or suggestions? thanks in advance....
indyF-350psd is offline
post #2 of 3 (permalink) Old 04-11-2008, 09:51 PM
********* and Mafia #90
Bcarriveau's Avatar
Sir, you will drain it with lower plug of 2. you will then will fill it with motorcraft mercron multi-purpose automatic transmission fluid XT-2-QDT or mercron equivalent.. when i fill it i pump it full till it starts running out of the fill plug(higher or the 2) and let it run out till it stops. Important not to have to much. then you are done.. if you tq your plugs they will go to 27NM of 20lb/ft
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 3 (permalink) Old 04-11-2008, 11:38 PM Thread Starter
thanks alot!
