door ajar light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by guardrail, this thread has received 4 replies and been viewed 727 times.
post #1 of 5 (permalink) Old 12-08-2005, 07:34 PM Thread Starter
barely smokin'
Send a message via AIM to guardrail
door ajar light
My new truck has this light on, I've seen alot of people say use penatrating spray on the latches themselves and slam the doors a few times. What exactly does that do? If that doesn't work where can I trace the door switch wires to?
Thanks.
02 F250, CC/LB/4x4 4" lift w/ 35's
Straight pipe, barely smokin'
AFE Stage 1
guardrail is offline
post #2 of 5 (permalink) Old 12-08-2005, 08:11 PM
Registered User
I had that same problem with my 00' F250 ..I laughed when they told me that would fix it..it didn't make since to me that that would work...but it did and it will for you also...
the switch for the door is in the latch appaiently it gets dry and the contacts stick..thats the best that I can figure...as far as tracing the wires?? Goodluck with that.
Oh...and welcome to the Site
Phil
[B]2003 GMC 2500HD
It's got a few things done to it....
with more to come.
wideopen is offline
post #3 of 5 (permalink) Old 12-08-2005, 08:11 PM
Registered User
Phil
[B]2003 GMC 2500HD
with more to come.
wideopen is offline
post #4 of 5 (permalink) Old 12-08-2005, 08:40 PM
4cstr
When my light comes on its the passenger rear door. My daughter gets it shut...but not shut enough I guess. I have her re-open and pull closed a little harder and that seems to help it.
I have sprayed the latch and opening mechanism with WD-40. It seems to help a little, but admitedly I don't drive the truck as much as I used to.
Dave
post #5 of 5 (permalink) Old 12-09-2005, 07:11 PM
The switches are replacable as they are attached to the latch, but not apart of it. You rotate them and they will come out of the latch. Sometimes after closing the door they become loose. Spraying them does not fix them. The must be replaced.
PSDPlayer is offline
bent pushrods mrmcgoo 6.5L Diesel Engine 4 01-09-2009 01:37 AM
Cat fuel pressure flips Medium and Heavy Duty 10 01-08-2009 03:26 AM
LMM Engine Control Module Replacement ripmf666 GM Spec Info 0 12-28-2008 10:20 AM
BMW smoke story dalpilot 2003-2007 6.0L Power Stroke 1 08-23-2005 04:09 PM
TSL Boggers in 23 x 9.50 x 12? TooMuchBoost The Parking Lot 8 07-15-2005 11:17 AM
