high performance CPS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wftree, this thread has received 10 replies and been viewed 1119 times.
post #1 of 11 (permalink) Old 01-05-2006, 04:01 PM Thread Starter
what does not kill you ..
I have been following a HUGE thread on the TDS site about the IH blue cps part number 1807339C92. I needed a spare anyway
I will install today and see what happens.
wftree
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #2 of 11 (permalink) Old 01-09-2006, 01:22 AM
I've got one on order. You're talking about the CPS for the DT466 right?
dog3434 is offline
post #3 of 11 (permalink) Old 01-09-2006, 04:30 AM
4cstr
So the cps from the 466 will work in our trucks.
WOW...learn sumtin new everyday. Thats seriously cool. Yep...let us know how it works out please.
post #4 of 11 (permalink) Old 01-09-2006, 01:28 PM
There's a lot of talk on the FTW sight about it. Most people said it made the engine run a lot smoother and save some fuel. Some said it took a little off on the top end but nobody complained about it. It didn't hurt any of the trucks at this point. I'm tired of replacing mine once a year and hope this one will last a little longer.
dog3434 is offline
post #5 of 11 (permalink) Old 01-09-2006, 01:41 PM Thread Starter
Seems to be quieter and no noticable difference in performance. The Magnet is significannly stronger. I used the very scientific test called " how many paperclips will it pick up" test.
On performance since my truck weighs 11,500 a few extra ponies would be hard to notice. Some noted a difference in shifting with my 6 speed shifting is the same:roflmao:
wftree
wftree is offline
post #6 of 11 (permalink) Old 01-09-2006, 03:04 PM
BJS
The threads about it in the 94-97 forums over there have come to the point that it is a stronger magnet it provides a slightly stronger signal to the computer at a slightly earlier time. It is advancing the timing ever so slightly. I've still got my new spare so I'm sticking with the original ones for the time being.
IMHO the differences can easily be attributed to it working correctly and any power difference is negated once you throw a chip/programmer on there.
If they last significantly longer then that's a whole different can of worms. but I can't really complain about mine.... kocks on wood... it's still the original @ 150k .... knocks on wood ... referencing all of the service records for the truck.
BJS is offline
post #7 of 11 (permalink) Old 01-10-2006, 01:41 AM
That's great that its working for you. My original engine had 85K on it and went through 2 CPS. My current engine has around 26k but had to have it replaced before it left the garage. I'm putting this one in my truck and keep the one now as a back up.
dog3434 is offline
post #8 of 11 (permalink) Old 01-10-2006, 03:18 AM
fuzzys69's Avatar
would this work good for a 97 i want to get one as a spare just in case mine goes bad
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #9 of 11 (permalink) Old 01-10-2006, 01:26 PM
There's a whole thread about 94s to 97s. Check with BJS above to get details on its location.
dog3434 is offline
post #10 of 11 (permalink) Old 01-10-2006, 07:56 PM
barely smokin'
Send a message via AIM to guardrail
hmm I've read through most of the thread and the consensus seems to be smoother power, mabye not as much but smoother, and quieter. I'm thinking of getting one even though I've only got 38k miles. I'd love it to be a bit smoother.
02 F250, CC/LB/4x4 4" lift w/ 35's
Straight pipe, barely smokin'
AFE Stage 1
guardrail is offline
