05 6"alignment ??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 0 replies and been viewed 505 times.
post #1 of 1 (permalink) Old 06-12-2009, 02:14 PM Thread Starter
bootcamp's Avatar
05 6"alignment ???
I have had this 6" lift on my truck for several years now, but with the 18x10 wheels was wondering how many have had alignment issues if any mainly with the caster camber alignment bushing. These factory bushings are fix adjustment so there really is no way to even change the alignment unless you purchase after market bushings that are adjustable. Any feed back or links will be outstanding info for me.
Thanks Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
Alignment help please LiftedDuramax Duramax 2001-2004 (LB7) 1 12-12-2007 03:42 AM
Alignment powerstroke2003 General Ford Truck and Excursion 1 09-16-2007 04:56 AM
Alignment Issue imported_DagObx 1994-2003 7.3L Power Stroke 4 10-19-2006 10:56 PM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
Headlight alignment 4wydnr 1994-2003 7.3L Power Stroke 3 01-02-2006 11:11 PM
