F350 rear end - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dieseltool, this thread has received 4 replies and been viewed 1469 times.
post #1 of 5 (permalink) Old 06-13-2009, 10:56 PM Thread Starter
F350 rear end
Is the ring and pinon the same on a 2006 F350 srw and a drw?? I found a hot deal on some take offs. Thanks
1964 F100 429 C-6 cliped and C notched(project)
(SOLD)1994 F350 4x4, XLT, 5 speed, Extra cab, IDI Factory Turbo Diesel, 4:10, badges shaved, 3 1/2 inch exhaust, pump turned way up,waste gate closed, 4 inch lift, flat bed, 255-85-16's, warn 10,000 winch
2001 Excursion LTD, Badges shaved, Pinstriping removed, EDGE Juice with attitude, Exhaust, Stage 1 intake, ATS Turbo Housing, Banks Big Head, 6 inch lift, 315's, over boost controler, oil pressure crossover line, air intake heater plug mod, zoodad mod, Banks trans command, trans temp gauge, roof rack removed, High angle drive shaft from Jess, cowl hood, 05 grill, 08 diff cover
2006 F-350 CC LB 4x4 Wedgewood Blue 6.0 Auto Loaded, B&W turn over ball, Zoodad, Harpooned, LineX, Straight pipe exhaust, 08 diff cover, Harley grill, painted door handles, quad pod+one, cowl hood, Badges shaved, 6" Fabtech lift, 37" on stock 20's, Ride Rite air bags, Helwig sway bars front and rear, SCT by Innovative Diesel, Leer bed cover, 08 tail lights, 08 bed extender
Dieseltool is offline
post #2 of 5 (permalink) Old 06-14-2009, 07:30 PM
no.
jvencius is offline
post #3 of 5 (permalink) Old 06-15-2009, 12:11 AM
4play's Avatar
there are different rears for these trucks, if they both have the sterling 10.5" (good chance of this ) you are good to go. but its possible the dually could have a dana 80 and those are not interchangeable.
4play is offline
post #4 of 5 (permalink) Old 06-15-2009, 01:29 AM Thread Starter
The gears are out of a tow boss 2006 F350 if that makes a difference?? The guy has sold the truck and is trying to sell the gears. He swaped for 373 because of freeway driving. Is there a number on the side that I can cross to see what rear end it came out of?? I do belive that the fronts are the same??
post #5 of 5 (permalink) Old 06-15-2009, 10:25 AM
UpstateDieselGuy's Avatar
I wouldn't think that the DANA 80 and Sterling 10.5 setups are different, however I'm not certain. Chris
SOLD
UpstateDieselGuy is offline
F350 Rear blocks SuperCrutyPS General Ford Truck and Excursion 4 03-28-2008 04:48 AM
hit an run so how much for a new rear 03 F350 door? TriGuy General Ford Truck and Excursion 9 01-28-2007 08:34 AM
F350 DRW Rear Springs HeavyAssault Whats Been Sold 0 12-24-2006 02:58 AM
F350 rear lowering kit LargeCar The Parking Lot 3 11-07-2006 07:05 PM
Want 04 F350 rear bumper Paxamus Whats Been Sold 1 08-15-2006 02:55 AM
