265/75r16 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kirby05, this thread has received 11 replies and been viewed 3013 times.
post #1 of 12 (permalink) Old 06-14-2009, 06:08 AM Thread Starter
265/75r16
looking to replace the tires. What is a good replacement for 265/75R16. I was thinking of going a little taller
kirby05 is offline
post #2 of 12 (permalink) Old 06-14-2009, 07:48 AM
harry6.0's Avatar
285/75-16 is the next size up that most people use, its basically a 33in tire and stands a bit taller. This thread will likely get moved into the general section. Harry
harry6.0 is offline
kirby05 (06-26-2009)
post #3 of 12 (permalink) Old 06-14-2009, 02:26 PM
Just about Broke
midnight2004's Avatar
Chris
2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
AEM Brute Force HD Intake, GT4088 VGT Turbo, Spearco Intercooler, Custom EGR Cooler Delete,
H11 Head Studs, Fass 150/180, Custom Fuel lines, Custom Coolant Filter, Single 6" Stack, 2.5" Lift. 35x13.5 on 20's
midnight2004 is offline
The Following User Says Thank You to midnight2004 For this addition to TDG:
post #4 of 12 (permalink) Old 06-14-2009, 05:51 PM
I went with the 285 75 16 on the stock wheel and probably made a mistake in doing so...at least for my application. Since I tow medium trailer weight, I'm convinced the tire and wheel combo are causing just enough sidewall bulge to make the truck a little squirrelly. Technically speaking, the 285 requires at least a 7.5" wheel. My stock wheel is 7" wide.
'12 F350 CC DRW KR, with some stuff
'13 Redwood 36FL
Gun Control means using both hands.
"I can sum up the clash of religion in one sentence:
My Invisible Friend is better than your Invisible Friend." Anonymous
Spindrift is offline
The Following User Says Thank You to Spindrift For this addition to TDG:
post #5 of 12 (permalink) Old 06-14-2009, 09:12 PM
Powered By Ford
FordRacing200's Avatar
285 is fine, my friend put 315s on his stock aluminum wheels and towed all the time, my other buddy has 285s on his, both are 02 PSDs and he tows everything from hay to his JD skidder, definitly will look better with the extra meat in the wheel wells
FordRacing200 is offline
The Following User Says Thank You to FordRacing200 For this addition to TDG:
post #6 of 12 (permalink) Old 06-14-2009, 09:23 PM
255/85R16 will fit the stock rim perfect, and it's 33" tall too.
They have a lower load rating though (3000lbs each instead of 3415lbs)
I ran BFG Mud Terrains in the winter, and loved them.
_________________________________________
The Bridgestone A/T Revo in the 265/75E16 is the best all-around tire for a SRW IMO
BONE STOCK
444turbodiesel is offline
The Following User Says Thank You to 444turbodiesel For this addition to TDG:
post #7 of 12 (permalink) Old 06-14-2009, 09:35 PM
Powered By Ford
255/85 is too narrow though...IMO
post #8 of 12 (permalink) Old 06-14-2009, 09:38 PM
That's open to opinion, I prefer tall skinnys myself.
285's are too wide for stock rims, and that's not opinion.
BONE STOCK
post #9 of 12 (permalink) Old 06-15-2009, 01:17 PM
Black Smoke Junkie
despain85's Avatar
285's are fine on our rims. They measure out at 16x7.5, I ran 315s on mine and towed up to 15k and never had a problem. Bigger tires look better on out trucks to, the wheel wells are to large to run 265s.
Tyler
'03 CC 6.0, truxedo tonneau, cowl hood
Clarion in dash DVD, 10 in. Fosgate sub
4" Pipe w/ 6" tip
Tuned by Innovative
315 Pro Comp Xtreme All Terrains
SLAPS Member #166
despain85 is offline
The Following User Says Thank You to despain85 For this addition to TDG:
post #10 of 12 (permalink) Old 06-15-2009, 01:37 PM
They (stock) are 7" rims, 315's are stupid wide for them.
If you want wide tires fine, but buy the correct wheels to go with them.
I've seen a lot of guys stack tuners and run propane "without issues" too
BONE STOCK
295/75R16 tires??? bmaxwell45 General Ford Truck and Excursion 16 10-17-2007 02:03 AM
BFG Mud-Terrain , LT285/75R16 (33's) NGA Ram Whats Been Sold 10 10-10-2007 03:15 PM
Stock XLT Rim Toyo M55 285/75R16 ontherks Whats Been Sold 4 12-28-2006 08:00 PM
WTB: Set of 4 LT265-75R16 Load Range E Tires BlueRidgeRunner Whats Been Sold 0 12-04-2006 11:54 PM
315/75r16 ProComp AT's on 16x10 Eagles dondiesel444 Whats Been Sold 0 07-06-2006 11:36 PM
