Color code on speaker wire - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 3 replies and been viewed 2379 times.
post #1 of 4 (permalink) Old 06-14-2009, 08:51 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
So I put new(to me) speakers in my 06 CC. What are the polarities for the wires(which is positive and which is negative)? I can't seem to get the sound right.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 4 (permalink) Old 06-15-2009, 12:04 AM
4play's Avatar
the factory does not label +/- on their radio-speaker circuits. at this low of wattage and single channel op it is irrelevant. if you upgraded the speakers ot produce better sounf you might want to look into a radio head too.
4play is offline
jdydiesel (06-15-2009)
post #3 of 4 (permalink) Old 07-01-2009, 07:35 PM
Send a message via AIM to Pat M Send a message via Skype™ to Pat M
A trick that you can use is a 9v battery or if you have a 18v battery put a set of leads on the terminals and pop the speaker. If the speaker goes in reverse the leads and do it again. Now if it went out trace which is the positive side of the battery and there you go. You now found which is negative and which is positive. Typically I just run new wires into the doors since I don't use the stock headunits or wiring. Sorry couldnt be better help on the color code though.
03 F250 Oxford White SC, 4" ProComp spring lift, Alpine IVA-W200, a/d/s P4100 & P4100.2, a/d/s/ 335is, a/d/s/ 336is woofer, JL Audio 10W6, Fisher 8' MM1 plow, 4 150watt KC's, Magnaflow 3 1/2" DP w/4" exhaust and no cat.
03 Excursion EB, 4" ProComp spring lift, RandyEllisDesign light bar w/4 150watt KC's, BVG luggage rack, Alpine CVA-1005, a/d/s/ P850.2, a/d/s/ 336im, a/d/s/ 336is, JL Audio 10w6, AFE intake, Magnaflow 3 1/2" DP w 4" exhaust and no cat.
Xtreme Audio & Video
Pat M is offline
The Following User Says Thank You to Pat M For this addition to TDG:
jdydiesel (07-05-2009)
post #4 of 4 (permalink) Old 07-06-2009, 02:33 PM
Bigking's Avatar
It's easier if you hook a speaker up and turn it on. You will get real crappy bass response if the polarities are reversed. Try it one way the reverse it to see what sounds the best. I had to do that to mine. Then decided it still wasn't loud enough and put an amp in. You can run an amp on the factory deck, just need a high level input.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
The Following User Says Thank You to Bigking For this addition to TDG:
jdydiesel (07-07-2009)
interior color code 8yourv8 General Ford Truck and Excursion 10 01-11-2009 06:48 AM
Factory speaker wire colors?? Sloth 2003-2007 6.0L Power Stroke 2 11-21-2007 01:01 PM
'97 Ford paint color/code Illini Ram General Ford Truck and Excursion 1 06-09-2007 02:09 AM
RPM Signal wire color? boosted_blazer General Ford Truck and Excursion 0 11-25-2006 12:24 AM
Wire Color for Highbeams Lifted94XLT General Ford Truck and Excursion 0 09-21-2006 09:02 PM
