Drivers rear tire 06 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 4 replies and been viewed 631 times.
post #1 of 5 (permalink) Old 06-14-2009, 11:59 PM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
inside of the wheel is getting wet with oil, new caliper so that's not leaking. Would this be a inner or outer axle seal that is leaking? I have never had a rear end apart on this truck yet. 87K miles
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 5 (permalink) Old 06-15-2009, 02:10 PM
Powerhouse Gypsies
spgtti72's Avatar
Inner I think. I had the same problem, didn't have time to mess with it , so the dealer did it for $180. It also lubed up the e-brake shoes but I told them to just clean them off and it still works fine. The service writer just wrote it up as an axle seal.
'99 F250 SC, 2wd, DP
spgtti72 is offline
The Following User Says Thank You to spgtti72 For this addition to TDG:
Bcarriveau (06-15-2009)
post #3 of 5 (permalink) Old 06-16-2009, 07:02 PM
8yourv8's Avatar
can't you fix that with just taking off the wheel and brakes off?
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #4 of 5 (permalink) Old 06-16-2009, 07:10 PM Thread Starter
Bcarriveau's Avatar
, have no idea how rear axels are set up. never really looked..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 5 (permalink) Old 06-16-2009, 08:49 PM
8yourv8's Avatar
I think there a floater so you could just slide the axle out and pull the hub off change the seal then put it all back together.
8yourv8 is offline
Rear tire locking up powerstrokin94 1994-2003 7.3L Power Stroke 8 10-07-2007 05:31 PM
wtb drivers rear door latch 01 quad cab cookiemonsterblue Whats Been Sold 0 08-31-2007 08:01 PM
Dual Exaust Exits Before Rear Tire? 4cefed 2003-2007 6.0L Power Stroke 15 05-12-2006 03:22 AM
Large Rear Single Tire ? Up-n-Cummins Medium and Heavy Duty 13 01-11-2006 11:53 AM
SCT Drivers? FireRescuePSD 2003-2007 6.0L Power Stroke 20 10-06-2005 03:45 AM
