Tranny ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 9 replies and been viewed 1032 times.
post #1 of 10 (permalink) Old 06-16-2009, 10:42 PM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
Tranny ?
e40d behind a 5.4
e40d behind a 7.3
Interchangeable? Same?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 10 (permalink) Old 06-17-2009, 12:35 AM
Even if the bellhousings bolt up okay, wouldn't the torque converters have different stall speeds?
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
Bcarriveau (06-17-2009)
post #3 of 10 (permalink) Old 06-17-2009, 05:09 AM
StrokerDude's Avatar
The cases actually are a tiny bit different. The ones behind the gassers do not have that little inpection cover under the TC.
Alex C.
StrokerDude is offline
The Following User Says Thank You to StrokerDude For this addition to TDG:
post #4 of 10 (permalink) Old 06-17-2009, 05:18 AM
4play's Avatar
lots of differences between the two. but the pieces are interchangeable if need be. the thing is the e4od saw many many upgrades through the years, the diesel tranny always had the best or strongest pieces in them for the specific time.
4play is offline
post #5 of 10 (permalink) Old 06-18-2009, 10:04 AM
Former Ford AutoTrans Eng
Mark_K's Avatar
There never was an E4OD behind a 5.4L. The 5.4L only had the 4R100 and TorqShift behind it.
The 5.4L and 7.3L bolt patterns are different. The transmissions won't interchange.
Mark
Former Ford Automatic Transmission Engineer 1988-2007
Mark_K is offline
post #6 of 10 (permalink) Old 06-18-2009, 02:32 PM
Take it from the expert!
I'm gonna hi-jack for a post or two with a question of my own... Torqshift taking forever to actually engage into gear after moving shifter, sometimes up to 8 seconds and clunks hard into gear when it does go... Is that a sign of the trans gettin ready to go?
Alex C.
post #7 of 10 (permalink) Old 06-19-2009, 05:07 AM
4play's Avatar
the 5.4l was introduced in 97 and it did have the e4od until late 98 it was the e4od and then the 4r100 in late 98 and exclusively 99 and beyond, ( basically the same trans). they renamed the e4od the 4r100. the 4r100 has a few upgrades over the last generation of the e4od. and the e4od parts are completely interchangeable with the 4r100 and vice/versa.
4play is offline
post #8 of 10 (permalink) Old 06-19-2009, 09:43 PM
Mod Friendly Title
Zaairman's Avatar
The E4OD was behind the 5.4 in F-150s (1997-1998ish)... Dunno why you'd want to put the same tranny behind a 7.3 without beefing it up some.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 10 (permalink) Old 06-23-2009, 01:46 AM Thread Starter
Bcarriveau's Avatar
Its not for me, its cause my buddy needs one and found one cheep from a 5.4 but does not want to put more money into the truck then he has to.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #10 of 10 (permalink) Old 06-26-2009, 10:37 AM
myf350's Avatar
I know they take the same internal parts. I smoked my tranny @ 183k, has 278k on it now. I ordered a rebuild kit from Dial-a Clutch and the kit was for an E4Od or a 4R100. There where different variations of each one as to how to put it together, but it was still the same rebuild kit. I think it was said previously, but the OBS had E4OD's in them.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
hp vs tranny Sabbath5.9 5.9L Cummins (2003-2007.5) 30 02-05-2008 09:09 AM
Which tranny 6.6 MaXi GM Transmissions 1 01-23-2008 03:04 AM
tranny just visiting 1994-2003 7.3L Power Stroke 7 06-11-2006 06:04 PM
Tranny gone 4wydnr 2003-2007 6.0L Power Stroke 4 02-15-2006 05:05 PM
