Tranny help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 8yourv8, this thread has received 2 replies and been viewed 567 times.
post #1 of 3 (permalink) Old 06-17-2009, 01:25 PM Thread Starter
8yourv8's Avatar
Tranny help
hey guys,
last night my tranny stuck in a higher gear at the light's once. Do you think it could be the shift solenoid?
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #2 of 3 (permalink) Old 06-18-2009, 03:44 AM
4play's Avatar
did you have a o/d light or check engine light on or flashing. you might have missed it. either way check for codes first. also check fluid condition and level. these transmissions have a "fail safe" mode that can be activated in the event of a sensor or solenoid failure. sounds to me ike it might have seen a intermittant failure with a sensor or solenoid and that should have stored a code..
4play is offline
post #3 of 3 (permalink) Old 06-18-2009, 02:26 PM Thread Starter
8yourv8's Avatar
no codes and working fine now ?
8yourv8 is offline
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
Tranny? 2tonePSD 1994-2003 7.3L Power Stroke 7 03-11-2008 02:45 AM
What Tranny? cumminsdiesel General Dodge Discussion 3 07-15-2007 03:31 AM
I Need A Little Tranny Help! kylecollings 5.9L Cummins (Pre 1994) 0 01-21-2007 05:57 PM
New Tranny Mod!!!!!!!!!!!!!!! NMU98 2003-2007 6.0L Power Stroke 67 03-21-2006 01:15 AM
