Which Gears? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 8yourv8, this thread has received 10 replies and been viewed 841 times.
post #1 of 11 (permalink) Old 06-17-2009, 06:36 PM Thread Starter
8yourv8's Avatar
Which Gears?
Ok so I have 373s in my truck would it be better to go with 410s? And how much MPG would I lose?
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #2 of 11 (permalink) Old 06-18-2009, 12:07 AM
I Wanna Go Fast!
brentos's Avatar
you probably wont notice much of any mpg difference but will probably feel a little difference in responce
brentos is offline
post #3 of 11 (permalink) Old 06-18-2009, 02:28 PM Thread Starter
8yourv8's Avatar
what are you running for gears?
8yourv8 is offline
post #4 of 11 (permalink) Old 06-18-2009, 02:39 PM
For your 35" tires, I'd go with 4.10's unless you're towing heavy, then you should look into 4.30's.
BONE STOCK
444turbodiesel is offline
post #5 of 11 (permalink) Old 06-18-2009, 03:04 PM
bootcamp's Avatar
I just had my gears swapped over to 4.10's last month. Didnt really pick up any fuel milage increase on the highway but milage is a little better in town. My rpms are pretty close to stock. It was a pretty hard choice for me to make between the 4.10 or 4.30 gears. I will be pulling my camper this time home and will find out if it really help with my towing milage. I ran my truck the whole time home with out the programmer on it and deffinatley could tell that the gears had been change. But again no change in fuel mileage.
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #6 of 11 (permalink) Old 06-19-2009, 02:03 AM
Lower gears will help with in-town mileage, but you have to get really low to make a difference in highway mileage (as long as you drive for mileage - not speed)
I can keep my truck in the 14-16 range in town if I pay attention, 18-19 on the highway empty, and that's with 4.30's and stock tires, but I have to drive like an old fart.
If you're running around at 75+ you're wasting your time worrying about mileage.
Gear it to cruise under 2000rpms (assuming a stock truck) and keep it under 60mph for maximum mileage.
BONE STOCK
post #7 of 11 (permalink) Old 06-24-2009, 01:22 AM Thread Starter
8yourv8's Avatar
ok so I look in to it well i was driving and at 100kph my trucks rpm is around 1850 is that too low?
8yourv8 is offline
post #8 of 11 (permalink) Old 06-24-2009, 02:31 AM
I Wanna Go Fast!
brentos's Avatar
what is 100kph???? i cruise at 70mph @ 2k rpm that is with 3.73s and 33s. but that is the lowest you want to cruise at really
brentos is offline
post #9 of 11 (permalink) Old 06-24-2009, 02:56 AM
StrokerDude's Avatar
Ummmm....... Sounds awesome How fast is that in MPH, might change my mind lol
Alex C.
StrokerDude is offline
post #10 of 11 (permalink) Old 06-24-2009, 06:14 AM Thread Starter
8yourv8's Avatar
Ok 100kph is about 62mph lol so that too low? seemd like the truck is lugging at that speed
8yourv8 is offline
4.30 gears for f-350 srw chvylac 2003-2007 6.0L Power Stroke 1 06-13-2009 03:42 PM
373 or 410 gears jerrbear1 6.7L Cummins (2007.5-2011) 41 02-25-2008 10:37 PM
Gears brister316 1994-2003 7.3L Power Stroke 7 12-10-2007 07:01 PM
Gears StrokerDude General Ford Truck and Excursion 5 11-19-2007 02:23 AM
small power+more gears, does it equal more power, less gears?? dondiesel444 Medium and Heavy Duty 2 12-08-2005 11:00 PM
