Need some mod suggestions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jvencius, this thread has received 0 replies and been viewed 364 times.
post #1 of 1 (permalink) Old 06-18-2009, 02:14 AM Thread Starter
Other than a T1 (if/when Joey releases them), I'm up in the air what my next mod should be--I've thought about a 38R (sticking with stock injectors for now) but I know darn well "good enough for now" won't last too long so I could use some suggestions what to wrench on next...
Basic stuff:
2002 F-350 XLT
7.3 Powerstroke
ZF-6 manual transmission
Manual transfer case
Crew Cab/Short bed
Dark Toreador Red
"GO" mods:
Zoodad
Tymar air intake with CCV mod
Wicked Wheel
High-flow turbine outlet
Non-EBPV pedestal
MBRP T-304 stainless 4" turbo-back exhaust
ITP regulated return system
KCM stainless high pressure oil x-over line
AirDog + in-tank/Harpoon mods
DP-Tuner F5 chip
Fluidampr harmonic balancer
Melling Low Pressure Oil Pump
Bilstein 5100 shocks
Revtek 2.5" leveling kit
Dynatrac Free-Spin hub conversion kit
Moog ball joints
Rough Coutry steering stabilizer
Michelin LTX AT/2 285/75R16E tires
Access Cover soft tonneau
Mag-Hytec rear differential cover
Dieselsite coolant filter kit
Fleetrite ELC coolant
Optima Red Top batteries
DiPricol Optix (boosht and fuel psi) and ISSPRO EV (pyro) gauges
ISSPRO hour meter
Termy ScanGauge
"Show" mods:
Bedliner-sprayed grille
2005+ Harley headlights
Marinco block heater plug
WAAG wheel-to-wheel step bars
Bullhide bedliner sprayed on the rocker panels, fender edges, step bars, and in the bed
XL vinyl floor
Pioneer DEH-5900iB iPod-compatible head unit into Boston Acoustics Pro speakers
Recon smoked cab light lenses
Black bedliner-sprayed front and rear bumpers
Lund grille inserts and bug deflector
jvencius is offline
Gpr Suggestions 2whlfreak 1994-2003 7.3L Power Stroke 3 12-07-2007 07:16 AM
Looking for Suggestions jp39bfd 5.9L Cummins (1998.5-2002) 7 10-17-2006 11:17 AM
Any Suggestions? Help! 03PSD 1994-2003 7.3L Power Stroke 2 09-29-2006 03:33 PM
Mod suggestions Tornsteel 1994-2003 7.3L Power Stroke 3 04-18-2006 02:42 PM
Mod suggestions! cmkworm 2003-2007 6.0L Power Stroke 14 04-13-2006 04:55 PM
