A/C Cuts Out - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kruser02, this thread has received 3 replies and been viewed 847 times.
post #1 of 4 (permalink) Old 06-22-2009, 02:29 AM Thread Starter
kruser02's Avatar
A/C Cuts Out
So here is the problem....my truck's A/C cuts out with any throttle (like it would under WOT) and comes right back as soon as you let it coast. It did this with the Xtreme tune and also does it stock and with my tow tune. This tells me it has to be electrical, but don't know what to test....compressor clutch? Any suggestions would be appreciated! (I leave for a 3000 mile trip Thursday)
04 F250 FX4 CC SB 6.0 PSD Torqshift
4in. Exhaust, RCD 62mm, RCD Tunes, FICM by Innovative, CCV Reroute, DIY Coolant Filter, RCD EGR Delete, ARP Headstuds, Dashdaq II, Banks Intercooler, Ride-Rite Airbags, Rancho 9000s, 285/75/16 BFG A/T
09 Jetta TDI DSG
kruser02 is offline
post #2 of 4 (permalink) Old 06-24-2009, 03:27 AM
Obviously Intuitive !
Pure *** guess, but maybe just check fuses ?
my ex's ac stopped on me today....
the rear was blowing, but not cold and front had no display....
pulled over and Mama looked at the book and said fuse 10 was ac clutch...
so without a spare, I swapped the 10 & 11 location fuses and it came back on !
Whew, 101 when we left the restaurant in Furt Wurrh would have made for a sweaty drive !!!
good luck....
02/12 f250 CC SB Lariat Ultimate 4x4
dpf filter back mbrp and airlift airbags
05/05 4x4 EB Excursion -gone but not forgotten SCT enabled 1/8th 8.9 seconds....
JohnBoyToo is offline
post #3 of 4 (permalink) Old 06-24-2009, 01:56 PM Thread Starter
kruser02's Avatar
I did check the fuses...all good there. Going to an A/C place today to have them put some gauges on it. I talked to an A/C guy I know and he believes that it is likely just a little low on refrigerant.
09 Jetta TDI DSG
kruser02 is offline
post #4 of 4 (permalink) Old 07-06-2009, 03:25 AM
Never a dull moment
BigGreen's Avatar
Did you get this fixed? Mine was also cutting out while driving, but it would cool a little while stopped. It ended up that my compressort clutch was a littel worn and was out of spec, so the clutch was slipping. I removed the clutch from teh compressor and took out a shim to tighten up the gap. It's doesn't slip anymore.
'95 PSD w/ a couple mods. Really it's nothing special, except for the fact it's frigin awsome!!!
BigGreen is offline
Who Cuts Your Hair? NukleusX The Parking Lot 43 02-13-2009 02:18 AM
12 Valve cuts out and pops when accelerating ant12 5.9L Cummins 12 Valve (1994-1998.5) 12 01-13-2009 06:38 PM
scheid lazer cuts dangerous196 Whats Been Sold 3 01-02-2008 11:05 PM
Man cuts down Mexican flag... Zaairman The Parking Lot 24 10-04-2007 08:30 PM
timing short cuts dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 5 02-19-2007 09:27 AM
