rcar911 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rcar911, this thread has received 20 replies and been viewed 1101 times.
post #1 of 21 (permalink) Old 06-23-2009, 04:15 PM Thread Starter
Cool rcar911
need help. replacing bad ball joint on 2003 7.3 f250 super duty 4x4. got to the part where you pull out bearing after removing 4 nuts from back and it will not pull out. (yes i did remove snap ring and washers from front) if i use a puller would it damage u joint or axle?? first time trying this do to unemployment in MI. all help appreciated.
thank you,
robert
rcar911 is offline
post #2 of 21 (permalink) Old 06-23-2009, 04:25 PM
********* and Mafia #90
Bcarriveau's Avatar
Moved and...
if you have the hub out, and the snap ring and washer from the axle shaft, abs line disconnected, and the 4 nuts off it should come out fairly simple, maybe needs a little tap of a hammer, you can use a puller yes but should not be in there that tight.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
rcar911 (06-23-2009)
post #3 of 21 (permalink) Old 06-23-2009, 04:30 PM
Bcarriveau's Avatar
Where are my manors, Welcome to the site man
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #4 of 21 (permalink) Old 06-23-2009, 04:40 PM Thread Starter
, i am off to go buy a puller because it will not pull off even tapping with a mallet. I even tried putting the wheel back on and still could not get it out.
Thanks, Again
Robert
P.S. and thanks for the welcome.
rcar911 is offline
post #5 of 21 (permalink) Old 06-23-2009, 04:43 PM
Bcarriveau's Avatar
maybe just give a parts store a call, alot of them rent them out so you dont have to buy them
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #6 of 21 (permalink) Old 06-23-2009, 05:06 PM
Mod Friendly Title
Zaairman's Avatar
You don't need a puller, just a whole lot of loving from a BFH.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #7 of 21 (permalink) Old 06-23-2009, 05:09 PM
Bcarriveau's Avatar
, i would be worried about damaging the wheel hub with a BFH..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 21 (permalink) Old 06-23-2009, 05:47 PM
Mod Friendly Title
Zaairman's Avatar
If you can damage it from a hammer, then it was needing replacement anyways. I'm thinking a nearly 8000lb truck puts a lot more force on that hub than a little hammer does...
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 21 (permalink) Old 06-23-2009, 05:50 PM
Bcarriveau's Avatar
Well what is it, a little hammer or a BFH cause i know a 20lb sledge will do more damage then normal use will like an egg, put equal pressure on it and it wont break, put more force on one area then another you will have a mess.
the salt in the winters up here make things really hold together well
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #10 of 21 (permalink) Old 06-23-2009, 09:52 PM Thread Starter
sticky hub
well i went and got a puller. put it the hub and cranked on it a while, and it just did not seem to want to come off. I sprayed the one part that seemed what i think is the seam where makes contact with pb blaster and then i will try the puller again. That thing must really be rusted on there.
Thanks again for the help
Robert.
rcar911 is offline
