Mag Hytec front D60 cover? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jvencius, this thread has received 4 replies and been viewed 774 times.
post #1 of 5 (permalink) Old 06-24-2009, 05:11 PM Thread Starter
Is the Mag-Hytec cover for the front Dana 60 a good idea or is it more of a solution in search of a problem? I'm coming up on my next service interval and if the MH cover is worth the (considerable) expense, now would be the most convenient time to get it.
jvencius is offline
post #2 of 5 (permalink) Old 06-24-2009, 06:51 PM
Mod Friendly Title
Zaairman's Avatar
Unless you do a whole lot of four wheeling, I'd pass on it.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #3 of 5 (permalink) Old 06-24-2009, 07:05 PM Thread Starter
Thanks, I was leaning the same way. Already this service, with me doing all the work myself, is probably going to wind up costing right around $400 (new Redline synthetic fluids in EVERYTHING, new filters every place I have one, etc...) so avoiding another $200+ expense is a good thing.
jvencius is offline
post #4 of 5 (permalink) Old 06-25-2009, 06:53 AM
SLAPS President
teamroper60's Avatar
Images: 9
I have that cover on mine and if I had it to do over, I would save the money.. The way it is built to work on a Super Duty, you don't really gain anything from it. It hardly holds any more fluid that the stocker.
It doesn't even have a cosmetic advantage to it, since the fins are only above the steering gear and can't be seen unless you are either under the truck or have a lift...
The only advantage I see to it is, I will never have to remove that cover again to change the fluid since it has a drain hole in the bottom.....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #5 of 5 (permalink) Old 06-25-2009, 12:34 PM Thread Starter
I've managed to talk myself out of a Mag-Hytec cover and into ONE OF THESE. It's good-looking, stupidly strong, and if the quality of my hub conversion is any indicator it's very very high quality. Also, the Dynatrac cover splits the difference (a little unevenly) between the $$$ for a MH cover and the functional but "blah" looking stocker so that's not too bad.
jvencius is offline
Acceptable wear to front cover (LPOP) midwestoffroad 1994-2003 7.3L Power Stroke 3 02-09-2009 06:49 PM
7.3 block, heads, cam, front cover Macktruckdriver Whats Been Sold 9 04-02-2008 10:04 PM
Mag-Hytec dif cover question fine69 General Ford Truck and Excursion 4 01-06-2008 05:15 AM
broken front cover housing Dualie 1994-2003 7.3L Power Stroke 0 07-23-2006 06:52 AM
f/s front grill cover for gm dmax 2004 f250 psd Whats Been Sold 0 01-23-2006 02:44 PM
