power rear slider - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 8yourv8, this thread has received 8 replies and been viewed 1788 times.
post #1 of 9 (permalink) Old 07-04-2009, 04:25 AM Thread Starter
8yourv8's Avatar
power rear slider
Anyone have there rear slider make niose well driving?
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #2 of 9 (permalink) Old 07-05-2009, 02:33 AM Thread Starter
8yourv8's Avatar
anyone?
8yourv8 is offline
post #3 of 9 (permalink) Old 07-06-2009, 02:29 PM
Bigking's Avatar
Were you trying to open or close it at the time? Mine stopped working on me.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #4 of 9 (permalink) Old 07-06-2009, 03:35 PM
Banned
What kind of noise, rattle, wind, squeak... I have not noticed it on mine. But I suppose know I'll listen and find another noise to annoy me...
wastedwagesracing is offline
post #5 of 9 (permalink) Old 07-07-2009, 04:06 AM
Super04Duty's Avatar
No noise from mine. But it opens and closes REALLY slow.
-brian
'04 F-350; CC, LB, SRW
'00 Dodge Neon; AutoX car
'04 VW Touareg; Her car
'57 Chevy Truck; 3200, life long project extraordinaire, 11 years and counting
'47 Dodge 1.5-ton, Cummins swap canidate
Singles Club Member #70
Super04Duty is offline
post #6 of 9 (permalink) Old 07-07-2009, 05:38 AM
4play's Avatar
hey guys, there is a TSB that addresses a concern with the rear slider binding, noise is not an issue thats addressed but as we all know alot of binding concerns have associated noises with them.
tsb# 06-15-5
FORD: 2004-2007 F-Super Duty
ISSUE:
Some 2004-2007 F-Super Duty vehicles, equipped with a power sliding rear window (back glass), may exhibit a stuck or binding concern. This condition may be due to the center glass not being positioned correctly inside the upper or lower channel, the channel being warped, bent, or center glass de-bonded
4play is offline
post #7 of 9 (permalink) Old 07-07-2009, 01:00 PM
Bigking's Avatar
Mine started opening and closing slowly before it stopped. Now it's a manual sliding window. I have not yet found a part number for it.
Bigking is offline
post #8 of 9 (permalink) Old 07-07-2009, 07:16 PM
4play's Avatar
these are the part numbers from the tsb.
6C3Z-2842006-B Rear Window Center Glass Assy
4C3Z-1523394-AA Motor and Cable Assy
6W7Z-19B508-A Urethane Adhesive
4play is offline
post #9 of 9 (permalink) Old 07-07-2009, 09:17 PM Thread Starter
8yourv8's Avatar
When its closed all the way it squeaks untell i open it a 1/8 inch or less
8yourv8 is offline
PWR rear slider how do you remove glass (05) BKB General Ford Truck and Excursion 5 02-19-2009 12:43 AM
Power Rear Slider Mike_B General Dodge Discussion 0 12-18-2007 05:24 PM
Power Rear Slider No Worky??? Levi'sford General Ford Truck and Excursion 3 08-14-2007 03:17 PM
Power rear slider broken! ACC inc. General Ford Truck and Excursion 0 08-12-2007 05:40 AM
Power slider problem fine69 General Ford Truck and Excursion 11 04-18-2006 12:31 AM
