Hood insulation - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 10 replies and been viewed 2245 times.
post #1 of 11 (permalink) Old 07-05-2009, 11:01 PM Thread Starter
4cstr's Avatar
Images: 35
Hood insulation
Does anybody know what the hood insulation is made from? When I blew oil this winter...it soaked my hood insulation. Now that it has gotten warm...I am dripping oil everywhere. I just wonder if I can powerwash this thing when I take it down. I don't want to leave it out...I am sure it cuts down noise a little bit. But...I am tired of the oil drips.
~Dave~
4cstr is offline
post #2 of 11 (permalink) Old 07-05-2009, 11:23 PM
Banned
Dave I'm not sure if it's the same material. But on my Chevy 95 gasser every spring I would power wash under the hood. Including the hood insulation and it never hurt is. You just to to be a bit careful that once it's soaked you don't blow it apart.
wastedwagesracing is offline
post #3 of 11 (permalink) Old 07-05-2009, 11:34 PM Thread Starter
4cstr's Avatar
Images: 35
Thanks Doug. I would apply a liberal amount of Simple Green to soak in...then either power wash it off...or use my garden hose sprayer.
~Dave~
4cstr is offline
post #4 of 11 (permalink) Old 07-05-2009, 11:43 PM
Banned
Forgot to mention I also would remove the under hood light bulb. If the cold water did not get it the pressure would.
post #5 of 11 (permalink) Old 07-05-2009, 11:45 PM Thread Starter
4cstr's Avatar
Images: 35
Originally Posted by wastedwagesracing View Post
Forgot to mention I also would remove the light bulb. If the cold water did not get it the pressure would.
I've had my hood open so many times that I took the light out for fear of running down the batteries
~Dave~
4cstr is offline
post #6 of 11 (permalink) Old 07-05-2009, 11:48 PM
strokin6L's Avatar
You know the '05-'07 trucks never had hood insulation. So i think removing it wouldn't be that much noisier in the cab.
strokin6L is offline
post #7 of 11 (permalink) Old 07-05-2009, 11:50 PM Thread Starter
4cstr's Avatar
Images: 35
The 6L were a bit quieter than the 7.3L were.
~Dave~
4cstr is offline
post #8 of 11 (permalink) Old 07-05-2009, 11:55 PM
Get a better stereo and you'll never notice the engine noise...
jvencius is offline
post #9 of 11 (permalink) Old 07-05-2009, 11:58 PM
Traveler1's Avatar
2005 FORD F250 PSD 6.0L 4X4 35,XXX Miles
..........Recon Smoked Lenses all the Way
Traveler1 is offline
post #10 of 11 (permalink) Old 07-06-2009, 10:25 AM
UpstateDieselGuy's Avatar
I know my '04 doesn't have a blanket to keep it warm Chris
SOLD
UpstateDieselGuy is offline
new hood mxchase General Ford Truck and Excursion 4 02-24-2011 07:05 AM
Shop Insulation KWT800 The Parking Lot 8 02-15-2008 07:09 PM
Turbo insulation from ATP question goatman1419 2003-2007 6.0L Power Stroke 2 10-28-2007 02:19 PM
Insulation on Intercooler tube? Ghostrider304 1994-2003 7.3L Power Stroke 20 10-22-2006 02:45 PM
New Hood SpicyJam Dodge Performance Forum 7 04-26-2006 10:53 AM
