door ajar - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buffalobob, this thread has received 3 replies and been viewed 636 times.
post #1 of 4 (permalink) Old 07-06-2009, 10:37 PM Thread Starter
buffalobob's Avatar
door ajar
anybody know where the door ajar switches are located. mine light suddenly came on and i dont even know which door is the culprit. any ideas on troubleshooting which door.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #2 of 4 (permalink) Old 07-07-2009, 05:48 AM
4play's Avatar
i have the capability of checking these with a scan tool, but if you dont have a enhanced scan tool i would just recommend lubing them all. you can lube them one at a time and open/shut door a couple of times to see which door is the culprit.
the ajar switches are located inside the door and mounted to the bottom of the latch. all you need to do to lube them is take and spray can of penetrate/oil or silicone spray, then open the door and spray directly into the latch and then gravity will kick in and soak it into the ajar switch. you can actually take a screwdriver and work the latch claws open/shut if you hold the door handle too. or just open/shut the door a few times to remedy. i recommend doing one door at a time just so you can verify which one was sticking.
also i dont know off the top of my head but some models will give you an extra chime once when a door is opened with the key-on or engine running. if all but one door chimes once when opening then the faulty switch is on the door that doesnt give the extra chime.
4play is offline
buffalobob (07-07-2009)
post #3 of 4 (permalink) Old 07-07-2009, 11:31 AM
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
Spray all door latches with WD40, open and close several times repeating application of WD40.
HeavyAssault is offline
The Following User Says Thank You to HeavyAssault For this addition to TDG:
post #4 of 4 (permalink) Old 07-07-2009, 02:42 PM Thread Starter
buffalobob's Avatar
just a big thanks here. wd40 fixed my problem. i am back to being extremely happy with my truck
Door Ajar AGAIN!!!! 99_stroker 1994-2003 7.3L Power Stroke 6 03-15-2008 12:14 AM
door ajar 99_stroker 1994-2003 7.3L Power Stroke 11 02-04-2008 01:19 AM
'Door Ajar' lamp staying on w/ door closed??? BlownGreenGP General Ford Truck and Excursion 4 02-03-2008 04:22 AM
Door Ajar Dingger Go Away frydaddy 1994-2003 7.3L Power Stroke 3 11-03-2006 11:23 AM
door ajar light guardrail General Ford Truck and Excursion 4 12-09-2005 07:11 PM
