Safe Reliable Power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by truckerstyle04, this thread has received 4 replies and been viewed 830 times.
post #1 of 5 (permalink) Old 01-11-2006, 07:23 PM Thread Starter
Safe Reliable Power
Hey, Everyone My Name is Drew and I am new to the forum. I just got a 04 fully loaded F-350 diesel 6.0 with auto trans, extended cab short bed FX4 with a plow, It only has 12,000 miles on it. Ok I want to do some power adders but I don't want anything crazy. I would like more low end power to help it get to where the turbo really kicks in. But mostly I want it to sound good have good reliable power and last for a long time. I do lots of cross country driving so I am looking to put miles on this truck. Also I would like to add gas milage but I know thats asking alot. I don't do any towing but I do haul hay and corn in the back all summer, and plow in the winter. I am scared about the trans specially with plowing and was wondering what I could do to extend the life of it as well. I know I have asked alot but this is the first Diesel I have owned and I know you can get alot of power out of these things but I want to do it safe reliable and right, Thanks
Drew
truckerstyle04 is offline
post #2 of 5 (permalink) Old 01-11-2006, 09:53 PM
fordt
In my opinion, first I would get a tranny guage. Plowing can be hard on the tranny, so if you want it to last, best to stay informed of whats goin on with the tranny temps.
post #3 of 5 (permalink) Old 01-12-2006, 12:12 AM Thread Starter
It has one stock on the truck but I dont know how correct that its??
post #4 of 5 (permalink) Old 01-12-2006, 12:32 AM
Supporting Vendor
I would add an aftermarket Trans temp for plowing. If the Ford one goes to the yellow it already got to hot.
I would recommend the TS Instigator 0-110HP for what you are descriping it works w/ the trans and has safe reliable power! You can find the FAQ's below.
http://www.tsperformanceproducts.com...tegate_faq.asp
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #5 of 5 (permalink) Old 01-20-2006, 12:59 AM
Can't go wrong with an SCT. Pulls out in minutes. Disables the EGR to reduce exhaust gas temps. Full trans control by way of altering the base programming and not buy piggy backing on the stock system. Lots of advantages over the competition.
PSDPlayer is offline
