HID problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nick0360, this thread has received 9 replies and been viewed 1371 times.
post #1 of 10 (permalink) Old 07-09-2009, 11:30 PM Thread Starter
nick0360's Avatar
HID problems
i just put a xentec 6000k kit in my truck and one light wont stay on just flickers dont know why check the wires plenty of times cant figure it out but the fogs work fine there are a coulpe of other guys around here with the same problem any suggestions?
nick0360 is offline
post #2 of 10 (permalink) Old 07-10-2009, 10:53 PM Thread Starter
nick0360's Avatar
anybody ?
nick0360 is offline
post #3 of 10 (permalink) Old 07-11-2009, 03:18 PM
tasman650's Avatar
same thing happen to me, you need to get a relay, the guy i bought mine from had relay kits for sale with it
do you have auto lights?
2005 F350 CC SB Harley Davidson Edition Blue, 4" Turbo Back Straight Pipe to Duels, SCT with Innovative Tunes, ARP Headstuds, EGR Delete, 20" ION Rims, 2.5" Cage Leveling Kit, 30,000k HIDS, Blacked Out Markerlights, Sidemarkers and Taillights
tasman650 is offline
post #4 of 10 (permalink) Old 07-11-2009, 04:49 PM
check your balast
TONKA TOY is offline
post #5 of 10 (permalink) Old 07-12-2009, 04:19 AM Thread Starter
nick0360's Avatar
k im gonna check the ballast tomorrow if its good then i was told to relay it tasman650where did you get your kit from online or local?
nick0360 is offline
post #6 of 10 (permalink) Old 07-12-2009, 03:43 PM Thread Starter
nick0360's Avatar
the ballast are fine but the passenger side still flickers so im goning to have to try a relay any suggestions?
nick0360 is offline
post #7 of 10 (permalink) Old 07-12-2009, 04:06 PM
tasman650's Avatar
i got mine local it has the plugs on it already that plugs right in to the ballast but you may be able to wire a relay in?
post #8 of 10 (permalink) Old 07-12-2009, 04:08 PM
Each ballast requires its own power supply from thr battery (or distribution block) as they need the amperage to ignite the lamp. This is best achieved using a trigger circuit to control a relay. Any 20A relay from you local autoparts store will suffice.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #9 of 10 (permalink) Old 07-12-2009, 09:52 PM
Mafia member #6
Rutcutter's Avatar
I can get the relay kits if you need one.
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #10 of 10 (permalink) Old 07-18-2009, 12:56 PM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
you are not getting the right amount of power to the ballast. Start with the conections and go from there. Some times the conectors look flush but are not. Also it is a good idea to add a relay to help with this power loss.
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
Problems... StrokerAce 5.9L Cummins (2003-2007.5) 0 08-20-2007 03:16 AM
problems with 04 mxchase 2003-2007 6.0L Power Stroke 8 08-16-2007 05:46 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
need help...problems with '04 jackedupF350 2003-2007 6.0L Power Stroke 6 09-04-2006 04:55 AM
Problems lukesdiesel 5.9L Cummins (1998.5-2002) 12 06-06-2006 02:36 AM
