swapping in a dana 80 srw - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JPscustoms, this thread has received 4 replies and been viewed 2154 times.
post #1 of 5 (permalink) Old 07-12-2009, 09:16 PM Thread Starter
JPscustoms's Avatar
ok so to get the correct ford bolt pattern you need the 99 to 04 dually axle....problem is its to wide to run as a srw.....whats cheaper to have it tubes and shafts narrowed or hubs moddifed???? also is it possible to get a dodge srw dana80 and change the front hubs on the ford to match that bolt pattern...then you just have to change wheels?????
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #2 of 5 (permalink) Old 07-12-2009, 10:01 PM
Get a 1999-2004 F350 DRW pickup and bolt it in. The wheels will stick out more, but other than that work. Cab/chassis version require spring pad relocation.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #3 of 5 (permalink) Old 07-13-2009, 12:45 AM
UpstateDieselGuy's Avatar
I believe I saw that River City Diesel had a kit available to convert the DANA 80 to a SRW. It might be worth a look. Chris
SOLD
UpstateDieselGuy is offline
post #4 of 5 (permalink) Old 07-13-2009, 03:13 AM Thread Starter
JPscustoms's Avatar
ya i looked at rivercitys, it looks good except i dunno if you can put the center caps on over the hubs cause they stick out so far
post #5 of 5 (permalink) Old 07-13-2009, 10:20 AM
Gotcha, that is probably a limitation.
SOLD
swapping a v-10 to a diesel dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 10 12-27-2007 03:59 AM
2001 5.9 CTD engine, tranny, tcase, dana 60 front, dana 80 rear both disk brakes GenesisBuilding Whats Been Sold 7 12-14-2007 10:02 PM
Swapping the VP44 StrokeThisGoat 5.9L Cummins (1998.5-2002) 2 04-04-2007 02:33 AM
3208 vs DT 466 - swapping kblackav8or Medium and Heavy Duty 12 05-03-2006 09:41 PM
Dana 70 disks on a Dana 80? ob1kobi 5.9L Cummins (1998.5-2002) 8 12-08-2005 08:34 PM
