what to do for 35's? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 12 replies and been viewed 1248 times.
post #1 of 13 (permalink) Old 07-14-2009, 10:57 PM Thread Starter
balz out's Avatar
what has to be done to tuck 35" tires under a f-350?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 13 (permalink) Old 07-14-2009, 11:58 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
you should be able to fit them with your lift.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 13 (permalink) Old 07-16-2009, 05:23 PM
Strokin05's Avatar
I have a 5inch lift on mine, or fabtech calls it a 5.5 and I clear them with no problems...
Strokin05 is offline
post #4 of 13 (permalink) Old 07-16-2009, 05:35 PM
Banned
I just put a 3.5" on my F-350 I plan on running 35's.
wastedwagesracing is offline
post #5 of 13 (permalink) Old 07-16-2009, 07:03 PM
member
Images: 19
My 35's are good and clear with the 2.5 level kit..
CrawfishPSD is offline
post #6 of 13 (permalink) Old 07-16-2009, 07:35 PM
Black Smoke Junkie
despain85's Avatar
My 35's are good stock. Just some rubbing at full lock, but it's nothing major
Tyler
'03 CC 6.0, truxedo tonneau, cowl hood
Clarion in dash DVD, 10 in. Fosgate sub
4" Pipe w/ 6" tip
Tuned by Innovative
315 Pro Comp Xtreme All Terrains
SLAPS Member #166
despain85 is offline
post #7 of 13 (permalink) Old 07-16-2009, 09:15 PM Thread Starter
balz out's Avatar
i have 315 procomps...they are not true 35" tires they are more like 33"
balz out is offline
post #8 of 13 (permalink) Old 07-16-2009, 09:22 PM
member
Images: 19
Right on, you'll be fine brother....
post #9 of 13 (permalink) Old 07-17-2009, 12:05 AM
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
For use off-road 4" or bigger in lift should be considered.
HeavyAssault is offline
post #10 of 13 (permalink) Old 07-17-2009, 04:31 PM
01PlatinumEdit's Avatar
For what it's worth...I started with ProComp 315x75R16 ATs at 2-1/2" lift, then went to 4" lift and they'd still rub a little at almost full lock under moderate suspension compression (think of turning into a parking lot at 10-15 mph). I'm now at 6.5" lift (measures 8" though) and they'll never rub again. You'll also need to trim the ends on the black plastic valance (if you have one) under the bumper. And don't forget your speedo error will increase if you keep stock gear ratio.
01PlatinumEdit is offline
Lowered on 35's tahoedmax Duramax 2001-2004 (LB7) 17 02-18-2008 03:58 AM
Those with 35's and Sct cwk 2003-2007 6.0 Tuner Forum 57 10-22-2007 03:52 AM
35's erikfowl General Ford Truck and Excursion 10 10-17-2007 02:04 AM
35's with 3.55? Hitechredneck 1994-2003 7.3L Power Stroke 12 06-25-2007 07:52 PM
How can I run a 13.5 with 35's? Summit6.6 Duramax 2006-2007(LBZ & LLY) 7 11-04-2005 05:53 PM
