Pressure Transducer thread size. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by EB.Bldr, this thread has received 3 replies and been viewed 546 times.
post #1 of 4 (permalink) Old 07-20-2009, 09:04 PM Thread Starter
EB.Bldr's Avatar
Anyone know the thread size/type of the pressure transducer on the high pressure line from A/C compressor to condensor?
Need to add a second one, thinking about just using a T if I can find one. I heard something about boss o-ring or something.
EB.Bldr is offline
post #2 of 4 (permalink) Old 07-21-2009, 01:20 AM
curious why are you adding a second one.
powerstrokemike is offline
post #3 of 4 (permalink) Old 07-21-2009, 08:40 PM Thread Starter
EB.Bldr's Avatar
Currently running 2 ECM's. The Ford ECM is running the A/C compressor and the Cummins ECM is running the fan clutch. Right now the fan dosent know to come on when the A/C is on. Thus the pressures are getting to high on the high side and the compressor is kicking off.
Just picked up a Dodge pressure transducer and was wondering if there is a T out there I could use insted of welding on an additional bung for the second tranducer.
EB.Bldr is offline
post #4 of 4 (permalink) Old 07-26-2009, 03:21 AM
I have in the past bought T's to retrofit for 134.
The sensor should be 1/8th o-ring pipe, the tee is generally 3/8's o-ring MxFxThread.
Another way is to use a relay for both inputs so it does not feed back, either turns the fan on.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
turbo oil inlet thread size Shaw Motorsports 5.9L Cummins (1998.5-2002) 2 04-04-2008 05:27 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Thread size in block for coolant temp sensor? centennial60 2003-2007 6.0L Power Stroke 2 06-21-2006 02:09 AM
