Bedliner sprayed fender? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jvencius, this thread has received 23 replies and been viewed 1812 times.
post #1 of 24 (permalink) Old 07-21-2009, 09:23 PM Thread Starter
I'm taking my truck to the Line-X dealer tomorrow to get the fenders/rocker panels re-sprayed and I'm unsure of how far onto the fender I should have them spray. Before, I just had the flat lip right around the edge of the wheel well sprayed but the lines would "flow" better from front-to-back if I had the whole bulged-out part of the fender sprayed. So, do you think I should go with just getting the lip re-shot or have the larger area sprayed?
Also, since I've stripped the door moldings off I'm going to have them spray higher onto the doors but do you think I ought to have them do just to where the metal starts to bend in towards the flat area of the door skin or should I have them spray right up to where the flat part of the door starts (about 2" farther than the beginning of the bend-in)?
jvencius is offline
post #2 of 24 (permalink) Old 07-21-2009, 11:39 PM
********* and Mafia #90
Bcarriveau's Avatar
why does it need respraying.. also i would stay with what is there. Not sure how it would look with the red piece over the bed liner..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 24 (permalink) Old 07-22-2009, 12:08 AM Thread Starter
The edges were starting to peel so before I started getting moisture/dirt trapped between the peeling liner and my paint, I got the old stuff off and am having it re-done.
jvencius is offline
post #4 of 24 (permalink) Old 07-22-2009, 12:08 AM
Banned
Your truck has a nice look to it. I would have it re-done just like it is now.
To much bed-liner can look like you doing a 500.00 make over.
wastedwagesracing is offline
post #5 of 24 (permalink) Old 07-22-2009, 12:09 AM
UpstateDieselGuy's Avatar
I have Line-X and went with the higher body line. I have no regrets; I think it looks great! Chris
[/QUOTE]
SOLD
UpstateDieselGuy is offline
post #6 of 24 (permalink) Old 07-22-2009, 12:12 AM
Banned
I think it depends on the base color. I like it on the gray. But I think it will be to much in your face on the red.
post #7 of 24 (permalink) Old 07-22-2009, 12:18 AM
It definitely can be a matter of taste.
SOLD
post #8 of 24 (permalink) Old 07-22-2009, 12:48 AM Thread Starter
Do you have a pic you could post of how the shop finished off the liner by the taillights?
jvencius is offline
post #9 of 24 (permalink) Old 07-22-2009, 10:26 AM
I will try to get one. The truck is filthy and it's raining, but it will be enough to get you jest. It has pretty much rained every day here.
SOLD
post #10 of 24 (permalink) Old 07-22-2009, 02:49 PM
Too much into it now...
Extended Power's Avatar
Like it was mentioned before: with the grey base color, it looks like it belongs there....but with the red....I would leave it the way it is...or change the color to a biege, and then do the whole fender lip. (So it looks factory.)
Extended Power is offline
Sprayed running boards drgriff Ford - Modification instructions, Product installs and Tech Articles 18 07-13-2009 01:43 PM
Bedliner-sprayed front bumper pic? jvencius General Ford Truck and Excursion 15 07-10-2009 02:07 AM
Sprayed my bumper yesterday... jvencius General Ford Truck and Excursion 33 06-13-2009 04:26 PM
sprayed rocker panels scotty2280 General Ford Truck and Excursion 30 03-17-2009 01:40 AM
Removing a Sprayed in Liner JLayne The Parking Lot 39 04-04-2006 05:46 PM
