Wet Weather Electrical Gremlins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by R_S_C, this thread has received 6 replies and been viewed 1121 times.
post #1 of 7 (permalink) Old 07-23-2009, 07:11 PM Thread Starter
So for the past year I've noticed that when we have a heavy downpour, and the truck sits through it some weirdness happens. First thing I will notice is the key fob no longer works and the vent fan will turn off and on with no keys in the ignition. If this doesn't freak you out enough to run and hide, the truck starts and runs fine, but the the transmission light blinks and the speedo jumps all around while driving. If you leave it for a day, it seems to "dry out" and all is back to normal. Lucky for me we've been in a drought so I haven't been too worried about fixing it. But with a possible wet winter coming up, I'm trying to venture to guess where to start...
At first I thought it might be the ECU getting wet, but wouldn't that cause random weirdness? The issues I see are the same every time. Is there a wiring harness or relay that would effect these particular systems?
Any help is appreciated!
2010 F250 6.4 - Stock
SOLD 2001 F250 7.3 Platinum Edition
Garrett Ball-Bearing Turbo/AFE Stage 2/AIH Plug/Sonnax/5" Exhaust/DP-TUNER Chip
R_S_C is offline
post #2 of 7 (permalink) Old 07-23-2009, 07:34 PM
plainredtruck's Avatar
Images: 11
You shouldn't have a GEM module, I don't think (don't remember when they changed that, though).
Maybe the IDM? I've changed mine. Didn't help.
Maybe the CPS? Also changed mine. Didn't help.
PCM? I certainly hope not.
All I can figure is there is some sort of chafed wire where the water has some effect. Maybe the extra weight of water on the wring causes it to contact a ground or a drop forms just at the right moment?
I'm stumped by mine as well.
I still get a hard skip on occasion while going down the road during the rain. It's as if the PCM is shorting very briefly. It throws a code, but I'm never close to a scanner.
Wish you well figuring it out.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
R_S_C (07-23-2009)
post #3 of 7 (permalink) Old 07-23-2009, 08:57 PM
balz out's Avatar
i have the same exact problem and was going to post a thread on here about it, it sucks...since mine is stick speedo does it when i get over 30 mph when im banging through the gears
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
The Following User Says Thank You to balz out For this addition to TDG:
R_S_C (07-24-2009)
post #4 of 7 (permalink) Old 07-23-2009, 09:11 PM
4play's Avatar
i have seen simular problems with the f-150, expeditions. there was a problem with the windshields leaking, water will travel down the a-pillar the drip behind the dash and run down into the fuse box and gem module. i have seen a few a these and cause about the same things you are complaing of. your truck doesnt have the gem module but it might be possible that water is getting into the fuse box? have you ever noticed the floor being wet/damp etc?
4play is offline
R_S_C (07-24-2009)
post #5 of 7 (permalink) Old 07-24-2009, 02:17 AM
bigastrk's Avatar
I had a very similar situation with my excursion and since then I have changed the dash wiring harness and all is well again. My heater/fan controls wouldn't work, the speedo would stop working and the dash lights would go off. Once I replaced the wiring harness all was well again.
03 6.0L Excursion < Sold
bigastrk is offline
The Following 2 Users Say Thank You to bigastrk For this addition to TDG:
plainredtruck (07-24-2009), R_S_C (07-24-2009)
post #6 of 7 (permalink) Old 07-24-2009, 12:58 PM Thread Starter
funny you should mention that, i do have a slight leak in my windshield and have been putting off getting it fixed. I think i'll start down that route. Just find it odd that water+electronics would cause the exact same behavior each time....would have thought it would be more random.
R_S_C is offline
post #7 of 7 (permalink) Old 07-24-2009, 03:26 PM
4play's Avatar
when we see these the glass shop will come out and reseal the windshield, if yours is cracked they will have to replace it, but if its pitted and such it would be a good time to replace it as the labor is basically the same.
4play is offline
Electrical gremlins please help. valcas1 1994-2003 7.3L Power Stroke 15 06-19-2009 08:25 PM
6.5 gremlins plowking 6.5L Diesel Engine 4 04-17-2007 05:17 AM
Gremlins Show your NFL Spirit! WNYPA The Parking Lot 4 09-17-2006 08:20 PM
Electrical Gremlins StrokerAce 5.9L Cummins (2003-2007.5) 14 03-29-2006 01:32 PM
