hi output alternators - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brad's-powerstroked, this thread has received 11 replies and been viewed 1288 times.
post #1 of 12 (permalink) Old 07-24-2009, 11:10 PM Thread Starter
brad's-powerstroked's Avatar
i got a 2002 f-250 with the 7.3, and my alt just let go. need a new one, i have a fisher v plow, so i would like a high output one for the plow and lights in the winter, what you guys know of?
brad's-powerstroked is offline
post #2 of 12 (permalink) Old 07-24-2009, 11:34 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
DB has everything you need.
http://stores.channeladvisor.com/db-starter-alternator
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 12 (permalink) Old 07-25-2009, 02:47 PM
SSpeeDEMONSS's Avatar
talk with Bill, bcarriveau about hi output alternators.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 12 (permalink) Old 07-26-2009, 02:22 PM Thread Starter
I found paperformance has pretty good prices, but the prices on the site that tank put up are better, i was thinking something in the 160amp range should be fine, tank have you used their alternators? nhow do they hold up, and lso do i really have to upgrade my charging wire, i think i would just run another wire parallel to the bat of the alt with a mega fuse, like the kits they show.
thanks for the replys
post #5 of 12 (permalink) Old 07-26-2009, 03:40 PM
Price isn't everything.
For example, how do you know you're getting a high power alternator when you order from DB? 14 so-called high power alternators bought as a group buy - weren't; and one other bought by another TDG member wasn't. There a four page thread on the group buy here and I don't recall the member who got what he thought was a 130 amp alternator but appears to be only a 105 amp alternator, a search should be able to turn up the thread.
I'd keep looking if I were you.
Alterparts.com or nationsalternators.com are two you might look into to.
FTG-05 is offline
post #6 of 12 (permalink) Old 07-26-2009, 04:11 PM
TANK'S 250's Avatar
Images: 38
Last I heard,..DB realized they made a mistake and sent out all new ones....
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #7 of 12 (permalink) Old 07-26-2009, 07:13 PM
UpstateDieselGuy's Avatar
They claimed that they had found the error, but we were several weeks into it and weren't confident that we would get the right output so we canceled the deal. I was part of that group buy. Chris
SOLD
UpstateDieselGuy is offline
post #8 of 12 (permalink) Old 07-27-2009, 12:52 AM Thread Starter
another question i have is how big is too big? is 200 amp almost to big, stock is 105 amp i believe, and in the winter when plowing, 8.5 xtreme v, with my heater, lights and plow going my lights dim when lifting the plow, now when plowing usally when i raise the plow, or angle i am at idle, and i dont plow full throttle so would i be better to get a 200amp alt that charges at 105 amps at idle, and also should i be worried about overcharging the batteries in the summer when i dont use the plow?
thanks
oh yeah i am know leaning towards one of these, 2 year warrenty other are only one.
post #9 of 12 (permalink) Old 07-27-2009, 03:07 AM
TANK'S 250's Avatar
Images: 38
mine is stock,..160amp
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #10 of 12 (permalink) Old 07-27-2009, 10:45 PM
********* and Mafia #90
Bcarriveau's Avatar
Yup, they told me they fixed their issues. i have not tried on or talked with them since. I wont talk them down as they gave me the 2K back with no hassle, but i will say getting lied to from the owner is a big deal to me.
I now have one that puts out more, in a large case for cooling, and at better price .
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
Dual Alternators battle cattle 2008-2010 6.4L Power Stroke 17 01-20-2009 05:22 PM
two alternators vcassens 2003-2007 6.0L Power Stroke 12 01-17-2009 04:58 PM
Dual alternators Heavyloader Duramax 2006-2007(LBZ & LLY) 3 08-22-2006 02:24 PM
Dual alternators Diesel Dog 1994-2003 7.3L Power Stroke 13 02-23-2006 03:14 AM
Battery light and Dual Alternators? fordt 2003-2007 6.0L Power Stroke 2 09-08-2005 11:08 PM
