XM Radio - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Motown Fire, this thread has received 6 replies and been viewed 751 times.
post #1 of 7 (permalink) Old 01-13-2006, 05:15 AM Thread Starter
#454
Motown Fire's Avatar
XM Radio
I am getting the Roady 2 and want to know were ya'll have your XM radio's mounted? Thanks for your help.
2011 Dodge 3500 DRW CTD CrewCab 4X4 G56
2012 PJ 40' Dual Tandem Flat Bed
Motown Fire is offline
post #2 of 7 (permalink) Old 01-13-2006, 11:12 AM
4cstr
I have the Delphi unit and I bought the mounting kit for it. Mine is mounted to the far right of the cubby area on the dash.
post #3 of 7 (permalink) Old 01-13-2006, 09:39 PM Thread Starter
#454
I was thinking of mounting it just above the cubby hole since I have the manual shift transfer case.
post #4 of 7 (permalink) Old 01-13-2006, 09:43 PM
fordt
That's where I mounted mine before I bought the XM ready head unit. It worked great.:Thumbup:
post #5 of 7 (permalink) Old 01-13-2006, 11:13 PM
I have siruis, but its basically the same thing. I went with the satelite ready deck, just so I wouldn't have more clutter. I think it was worth paying a little more.
hcr400ex is offline
post #6 of 7 (permalink) Old 01-21-2006, 10:11 PM
Here are some pics of my XM2GO installed in my Excursion.
The Panavise mount I used is the only one of its kind to utilize the ashtray/cupholder screw so no dash removal is needed. I ran the wires into the cubby hole where I drilled a hole out of site.
Panavise mount # 751072399 (panavise.com)
Panavise swivel # 685-PM
I ordered my PIE adpater to hook into my headunit from myradiostore.com.
The attenna for my Excursion is just above the window & R-View mirror outside and run along the window trim. In a P-Up, come in through the 3rd brake light.
Check out xmfan.com as they have pictures of mountings, but I think that mine is the cleanest install to date due to the panavise mount they have developed for the cupholder/ashtray.
Let me know if you have any questions.
Good luck.
Jeff
Name:	XM Bracket In Cup Holder-1.JPG
ID:	3242   Click image for larger version
Name:	Panavise Mount - Mounting Location.JPG
ID:	3243   Click image for larger version
Name:	Cubby Hole - Hidden Wires.JPG
ID:	3244   Click image for larger version
Name:	XM Roof Mount Under Window Trim.JPG
ID:	3245   Click image for larger version
Name:	Side View XM Radio Mount - L.JPG
beachbumcook is offline
post #7 of 7 (permalink) Old 01-21-2006, 10:18 PM
Opps, be careful as my Excursion is an auto and when I re-read your second post you said you had a manual... so not sure if the mount and radio will leave enough clearance or not for you... but for any automatic people this is the way to go.
