"Door is Ajar" light stays on - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hoot, this thread has received 6 replies and been viewed 650 times.
post #1 of 7 (permalink) Old 01-13-2006, 09:46 AM Thread Starter
hoot's Avatar
I got a freind with a 1999 SUperDuty. His "Door is Ajar" light stays on. Anybody know where to look first?
The PLane Will Fly
04 2500 DODGE 4x4, QC SB SLT, POWER WAGON and THE MIGHTY CUMMINS 305/555, Goerend 48, Triple Disk TC, BDFlex Flexplate, F1stix, HT62/71/13 SS Turbo , Arp Head Studs, TST PowerMaxCR, Smarty, Injen/Amsoil air intake, FASS 150, Di Pricol Boost,TransTemp and Fuel Pressure, H2 Hummer Wheels & Toyo Open Country M/T's, Kore Leveling, Kore Stabilizer Drop 5" RIP Rook 6" SS TIP, Mag-Hytec Rear and Trans, Defiant Dual Steering Stab Sys, Thuren Trac Bar, Carli Light Bar, Hella's, Bushwacker Fender Flares, AirChime K3LA Locomotive Horn, Western 8.6MPV V-Plow
Dynoed 5-17-08 541hp/1039tq
2004 DODGE PICS AND INFO
2001 Duramax PICS AND INFO
hoot is offline
post #2 of 7 (permalink) Old 01-13-2006, 11:07 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
I think you can try to spary WD40 into the hinge area, I have heard of peoples connections sticking and they have done that and it started working correctly..:Thumbup:
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 7 (permalink) Old 01-13-2006, 11:10 AM
4cstr
Spray some WD-40 into the latch area...inside the door. My passenger rear door was the only causing all the problems until I did that.
post #4 of 7 (permalink) Old 01-13-2006, 11:59 AM
Obviously Intuitive !
That has been know to do it....
but if not... not a hard thing to replace the sensor....
02/12 f250 CC SB Lariat Ultimate 4x4
dpf filter back mbrp and airlift airbags
05/05 4x4 EB Excursion -gone but not forgotten SCT enabled 1/8th 8.9 seconds....
JohnBoyToo is offline
post #5 of 7 (permalink) Old 01-16-2006, 01:09 AM Thread Starter
hoot's Avatar
We'll try the WD first.
Where is the sensor? In the door?
The PLane Will Fly
hoot is offline
post #6 of 7 (permalink) Old 01-16-2006, 01:25 AM
Its attached to the latch itself. If you pull the panel and the latch out, you can remove it and replace it. Pretty simple.
PSDPlayer is offline
post #7 of 7 (permalink) Old 01-16-2006, 01:40 AM
MIne stayed on one time because I forced to door open from inside when it was iced closed. It stayed on for 1/2 a day till it thawed out...
Unbroken is offline
