A/C not working at idle, compressor not cycling rapidly - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by paulkeith, this thread has received 6 replies and been viewed 3303 times.
post #1 of 7 (permalink) Old 07-30-2009, 11:00 AM Thread Starter
A/C not working at idle, compressor cycling rapidly or stays disengaged..only at idle
Edit: Woops, goof'ed the subject line.
At higher rpms and at speed, the a/c works fine and blows cold.
At idle, the compressor will cycle quickly (few times in a few seconds) or just stay disengaged.
No A/C trouble or work on the system since I've owned it, which is 3 years.
Help? I'm thinking low charge?
Thanks in advance,
Paul
paulkeith is offline
post #2 of 7 (permalink) Old 07-30-2009, 12:18 PM Thread Starter
included my sig:
2002 Arizona Beige F250 Ext Cab Short Bed. 7.3L 6spd 4x4 140k
2" leveling kit, 285/75 Mastercraft AT2's,Napa BFF, DiPricol Pryo/Boost, DP F5 NS/stock/hi/40/80/120/140agg-lope, Toolbox, Audio goodies, IH shiftknob
muffler delete, CCV reroute, AIH/Foil delete,
post #3 of 7 (permalink) Old 07-30-2009, 03:29 PM
4play's Avatar
rapid cycling could indicate a low charge, but if its cooling at higher speeds it doesnt sound like its low, and if its low enough it would cycle at all. it kinda sounds like you might have a weak clutch on front of the compressor or cycle switch acting up. i would lean toward the clutch. If you can catch it disengaged when it should be on then try tapping the front hub of the compressor. this usually works to verify a weak clutch field coil. note be careful cause if the compressor engages it might try to knock the hammer out of your hand.
4play is offline
paulkeith (07-30-2009)
post #4 of 7 (permalink) Old 07-30-2009, 04:19 PM Thread Starter
I was wondering the same thing, but figured a weak clutch would just get worse at higher RPM?
post #5 of 7 (permalink) Old 07-30-2009, 05:25 PM
myf350's Avatar
Could be that the gap is to big and it is slipping at low rpm. This can be be fixed by taking the clutch off and removing a shim and then reinstalling, which would decrease the gap between the clutch and the pulley.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
The Following User Says Thank You to myf350 For this addition to TDG:
post #6 of 7 (permalink) Old 07-31-2009, 06:14 AM
4play's Avatar
when i gap clutches i usually try to get the hub as close to the pully as possible but not allow them to touch and rub when free wheeling. the actual spec is ( 0.014-0.030 ) and can be checked with a feeler guage.
only problem with setting this gap is sometimes there is only one shim or one too thick to remove to "close" the gap. be carefull when removing the center bolt and front hub because sometimes the shims will fall out. the shims usually will stick inside the hub though and a small screwdriver or pick will get them out.
4play is offline
post #7 of 7 (permalink) Old 07-31-2009, 01:40 PM Thread Starter
intermittent connection at the clutch electrical connector. cleaned contacts with acentone, problem solved....for now.
Glowplug Controler Keeps cycling RonsPlc 7.3L and 6.9 IDI (Pre 1994) 1 03-09-2009 09:33 PM
Auto cold idle not working on 03 mmmdiesel 1994-2003 7.3L Power Stroke 2 03-04-2009 10:05 PM
05 6.0L Losing MPG rapidly Jakkle5 2003-2007 6.0L Power Stroke 21 02-10-2009 02:32 AM
No Heat At Idle, Luke Warm When Working SICKS-O 2003-2007 6.0L Power Stroke 9 12-23-2008 10:28 PM
Anyone else have this problem Rpm cycling Min8251 2003-2007 6.0L Power Stroke 3 05-06-2007 01:16 AM
