The 05 Ex has a new HFCM drain LEVER !!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JohnBoyToo, this thread has received 5 replies and been viewed 818 times.
post #1 of 6 (permalink) Old 01-13-2006, 03:21 PM Thread Starter
Obviously Intuitive !
Haven't verified it but found this in their online manual @
www.ford.com
might be on the new Superduty as well !
02/12 f250 CC SB Lariat Ultimate 4x4
dpf filter back mbrp and airlift airbags
05/05 4x4 EB Excursion -gone but not forgotten SCT enabled 1/8th 8.9 seconds....
JohnBoyToo is offline
post #2 of 6 (permalink) Old 01-13-2006, 11:09 PM
i wont believe it till i see it with my own eyes.....
get under your ex and look!
_CH_ is offline
post #3 of 6 (permalink) Old 01-14-2006, 12:13 AM
TDG Mafia Member #24
:agreed:
:grd
"Can You Keep Up?"
AUGSX is offline
post #4 of 6 (permalink) Old 01-15-2006, 12:41 AM
This is probably yet another case of when the book leads you a million miles from the fix. Perfect example is when you are doing the pinpoint tests and it says Measure resistance on a wire. Is resistance greater or less than 10K ohms. Less then tells you to fix the open and greater than says to put a PCM in it. And you think ummm if the wire has the correct resistance then why does it tell me to fix the open?
PSDPlayer is offline
post #5 of 6 (permalink) Old 01-15-2006, 05:13 AM
Morpheus cycles's Avatar
I'm gonna go check my 05 for it
Jay
11 GMC 3500 4x4 SLT Crew Cab
Dually club #78
Singles #19 Yeah I drive a Jeep too.
86 CJ7 Rebuilt from the frame up as a rockcrawler
Morpheus cycles is offline
post #6 of 6 (permalink) Old 01-23-2006, 04:06 PM
So anyone check this?
:grd
"Can You Keep Up?"
AUGSX is offline
