05 Headlights into an 04 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fire59Rescue, this thread has received 4 replies and been viewed 748 times.
post #1 of 5 (permalink) Old 07-31-2009, 02:35 AM Thread Starter
I recently aquired a super clean all original Harley Edition F350. As a volunteer firefighter I would like to install a strobe warning system in the truck, but I don't want to cut up an unmodified truck.
I'm considering installing a set of aftermarket 05 Harley headlights, and installing strobes in them - I won't feel bad cutting up aftermarket headlights.
My question is this - I understand that putting the 05 headlights into the 04 radiator support requires some clearancing - how much? Is it minor trimming that can be done nicely, or does it require hacking a big hole in the rad support?
Anyone whos done this please tell me how your install went, and what I might be letting myself in for....
Thanks
Gregg
Fire59Rescue is offline
post #2 of 5 (permalink) Old 08-01-2009, 05:49 AM
utlonghorns416's Avatar
Images: 1
I put 05s in my buddys 03. Its not that bad get a good dremel and a cutting wheel just make the circle for the back of the headlight larger in the balk head of the truck. Test fit as much as you can and take your time.
R.I.P Lewis Lamb (lambstroker6.o) Feb 13th 2010
"Life is all about the ride 513"
utlonghorns416 is offline
post #3 of 5 (permalink) Old 08-01-2009, 06:03 AM
Images: 1
https://www.thedieselgarage.com/forum...hlight=strokin
There is a pic of where I cut the holes larger, dont mind the honda photos. Friends beer and cameras sometimes do stupid things.
Hope this helps
post #4 of 5 (permalink) Old 08-01-2009, 02:31 PM Thread Starter
Thanks for the info - looks like I can do what I want without totally butchering the rad suppport.
BTW your avatar is awesome.....
Gregg
post #5 of 5 (permalink) Old 08-01-2009, 10:50 PM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
When mounting the strobe bulbs I placed mine pretty close to the turn signal bulbs. I had no clearance issues. With my buddies he mounted his to far from the stock bulbs and had to cut extra space in the header pannal for them to fit just right.
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
05 Headlights NYTMARE General Ford Truck and Excursion 13 02-07-2009 03:22 PM
HID headlights mxracer732 General Ford Truck and Excursion 19 01-08-2009 12:13 AM
headlights cajuncummins The Parking Lot 0 01-05-2008 05:16 AM
Headlights imported_fast_and_furious 5.9L Cummins 12 Valve (1994-1998.5) 8 12-31-2007 10:13 PM
obs headlights circle5 General Ford Truck and Excursion 3 01-03-2007 07:56 PM
