2009 F 350 Super Duty Tire Pressure Monitor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by beanboy, this thread has received 5 replies and been viewed 2668 times.
post #1 of 6 (permalink) Old 07-31-2009, 05:56 PM Thread Starter
Hello
I just purchased a 2009 F350 Super Duty and installed a 6 inch Fabtech Radius arm lift kit.
I changed tires to 37 x12:50 X 18 BF Mud
They only come in 8 ply and max tire pressure is 60psi vs the 10 ply 80 psi the tires the truck came with.
Went to Ford dealer to have them recalibrate the air pressure montior and I was told that it can not be done.
Does any one know how to fix or am I stuck with this until someone writes a new program?
Thanks in advance
beanboy is offline
post #2 of 6 (permalink) Old 07-31-2009, 06:43 PM
Originally Posted by beanboy View Post
Hello
Thanks in advance
Far as I know all new trucks with tire sensors when you change tires there is nothing you can do about it. But I'm not 100% sure
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #3 of 6 (permalink) Old 07-31-2009, 07:01 PM Thread Starter
Thanks Big Stroker
I have read a little further and am thinking about putting all 4 sensors in spare tire and air up to recommended pressure.
I read that on this form.
If anyone have any other ideas please advise.
beanboy is offline
post #4 of 6 (permalink) Old 07-31-2009, 08:35 PM
fine69's Avatar
Beanboy, did you get a warning light on your dash when you installed your aftermarket wheels? If so, how many miles did it take? I installed the Weld wheels and Nitto's I took off my 05, and I haven't got a Tire Pressure warning light at all. Hopefully it never comes on. If it matters, I took off the stock 20" wheels with less than 50 miles, so maybe the truck has to "Learn the sensors"?
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #5 of 6 (permalink) Old 08-01-2009, 02:46 AM
strokin6L's Avatar
Hello
Thanks in advance
Did the new rims have the tire pressure sensors in them...they should've?
strokin6L is offline
post #6 of 6 (permalink) Old 08-01-2009, 04:07 AM Thread Starter
Hi Guys
I still have the stock wheels that came with truck on it with the 37s
The Ford sensors are much different than that of the GM.
Gm seem to be in the valve stem and ford wrap around the whole inside of wheels.
I plan on installing all sensor into my 10 ply spare and running the recommended air pressure. (80lbs)
Will give the forum a few days to see if someone has better idea before I go ahead and swap out sensors.
If I do not hear any positive news I will post how all turns out.
beanboy is offline
Tire Pressure Monitor DELETE Slick Willie 2008-2010 6.4L Engine Tuner Forum 22 03-09-2009 10:00 PM
tire pressure monitor problem deere puller 2008-2010 6.4L Power Stroke 14 04-18-2008 04:26 PM
2007.5 2500HD tire pressure monitor system wharf rat Duramax 07.5-2010 (LMM) 7 02-08-2008 01:46 AM
Tire Pressure Monitor System Scott_M 2008-2010 6.4L Power Stroke 6 10-23-2007 11:18 PM
Anybody know anything about this Tire pressure monitor BS GruntTorque 2008-2010 6.4L Power Stroke 10 10-05-2007 03:02 AM
