load range d? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SICKS-O, this thread has received 10 replies and been viewed 1455 times.
post #1 of 11 (permalink) Old 08-06-2009, 12:04 AM Thread Starter
Slow 6.0
load range d?
i know our trucks are supposed to have E range tires but i dont plow or haul so can i get away with D range?
2006 F350 XLT 4x4
SICKS-O is offline
post #2 of 11 (permalink) Old 08-06-2009, 01:51 AM
yep, its no problem as long as they can carry the weight.
The last two sets of tires on my truck have been D's and there hasn't been one problem. I've towed a 7k lb trailer with a bed full of stuff and there was only a bit of sway when passing semi's and large vehicles on the freeway, but nothing too bad.
'99 F-350 Supercab Lariat built 2/13/99
Camper Package, TS 6-pos chip, DIY Tymar, 4" Magnaflow turboback SS Exhaust, 203* Thermostat, Coolant Filter, Upgraded Headlights/corner lamps, Custom center console with a sub
Autometer Guages were stolen!
MANUAL HUBS AND TRANSFER CASE!
mrit is offline
post #3 of 11 (permalink) Old 08-06-2009, 03:51 AM
********* and Mafia #90
Bcarriveau's Avatar
i tow and plow, i run Ds. just a softer tire.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #4 of 11 (permalink) Old 08-06-2009, 03:53 AM
Dually Club #3
jdydiesel's Avatar
I will never run D's on my rigs again. I ran them on my X and they where so bad that I couldn't tow. It was the scariest thing I ever did in a truck.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #5 of 11 (permalink) Old 08-06-2009, 12:09 PM
If you go up in tire size the D range load rating will be similar if not more than the stock E range.
Pat 2000 F250
5"exhaust with 6" tip, mac intake, foil delete and zoodad :ford
silverf250 is offline
post #6 of 11 (permalink) Old 08-06-2009, 01:51 PM
Banned
I think the section height of the tire has to come into play also. Seems like the more section height you have the more you need the "E" to keep the side to side sway under control.
wastedwagesracing is offline
post #7 of 11 (permalink) Old 08-06-2009, 03:05 PM
Yeppers--exactly. When I switched from the 285/75R16D BFG AT's I was running to the same size but E-rated Michelin LTX/AT2 tires I have now, the difference was dramatic. It wasn't a night/day difference, but I'm so much more stable cornering, especially when the truck is loaded, that I don't know I could ever go back to a D-rated tire for something that'll see a lot of loading. The BFG's had a high-enough weight rating to be alright when I was empty but when I was over 10K on the axles (yeah, just a wee bit over GVWR max) handling got a little scary so I doubt I'll ever go back to a D-rated tire when there's an E-rated equivalent.
jvencius is offline
post #8 of 11 (permalink) Old 08-07-2009, 12:35 PM
97_redstroke's Avatar
I am running D range tires now and it tows fine and gives a better ride on the highway than the E range tires that were on it when I first bought the truck.
'97 F-250 HD ext. cab shortbox, 5" mitre cut stacks, edge evolution programmer, DIY intake.
97_redstroke is offline
post #9 of 11 (permalink) Old 08-07-2009, 03:42 PM
Mod Friendly Title
Zaairman's Avatar
Mine has had D's on it since I bought it. No issues.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #10 of 11 (permalink) Old 08-07-2009, 05:50 PM
Bigking's Avatar
I switched to D's also. Alot better ride.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
18" Load Range E tires??? oscarflytyer General Ford Truck and Excursion 6 06-29-2009 12:41 AM
load range C tires? 7inchstack 5.9L Cummins 12 Valve (1994-1998.5) 8 04-09-2009 05:27 PM
load range c nicnic General Ford Truck and Excursion 8 07-15-2007 10:41 PM
WTB: Set of 4 LT265-75R16 Load Range E Tires BlueRidgeRunner Whats Been Sold 0 12-04-2006 11:54 PM
285 or 305 load range E Diesel Dog General Ford Truck and Excursion 0 04-11-2006 01:28 AM
