Steering/Suspersion help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Strokin05, this thread has received 27 replies and been viewed 1444 times.
post #1 of 28 (permalink) Old 08-11-2009, 12:18 PM Thread Starter
Strokin05's Avatar
Steering/Suspension help!
Alright guys here we go.. I have an 03 F-250, 6.0 with 101k on it. On the way to wok today at about 45MPH th truck went left for a brief second then snapped back staright... Then it did it again, and again and the last time it did it after it came back it had a "I want to go left or right feel to it" , like the death wobble.. Any suggestions? It is here with me at work now.. Any thing to check for? All help and info is appreciated
Thank you,
Mike
Strokin05 is offline
post #2 of 28 (permalink) Old 08-11-2009, 01:32 PM Thread Starter
Strokin05's Avatar
Alright guys, I got underneath the truck and started pulling on some parts.. It seems that # 6, and # 7 in this diagram (inner and outer tie rod) have excessive play.. I can get underneath there and move them up and down and back and forth
post #3 of 28 (permalink) Old 08-12-2009, 02:14 AM
I can count to Potatoe
if you have excessive play you need to replace those.
They should have NO movement in them, beside being able to rotate. You said tie rod, but in your diagram that is the drag link (diagonal "bar" from pitman arm to passenger side tire).
Either way if there is play they need to be replaced. Pref with moog components as they are greasable.
dayusex is offline
The Following User Says Thank You to dayusex For this addition to TDG:
Strokin05 (08-12-2009)
post #4 of 28 (permalink) Old 08-12-2009, 11:46 AM
I just replaced parts 4-9 on my 03 Ex. Bought from ford, cost about $350, and they are greaseable.
2006.1f250 is offline
The Following User Says Thank You to 2006.1f250 For this addition to TDG:
post #5 of 28 (permalink) Old 08-12-2009, 12:54 PM Thread Starter
Strokin05's Avatar
I meant to say drag link but couldnt edit it after I thought about that .. I did order the parts should be here Friday.. I tell you what that was a scary ride yesterday morning
Mike
post #6 of 28 (permalink) Old 08-13-2009, 12:55 AM
here is a trick my budies and i "learned" on the trail, before paint parts 6 and 7. Then transfer the marks over to the new part and you can get your adjuster setup. Surprisingly the alignment will be pretty much intact enough to get you home. Just remember to check your steeringwheel as this will determine if its off center or not.
dayusex is offline
Strokin05 (08-13-2009)
post #7 of 28 (permalink) Old 08-13-2009, 12:58 PM Thread Starter
Strokin05's Avatar
Thanks for the advice! I appreciate it
post #8 of 28 (permalink) Old 08-15-2009, 01:24 PM Thread Starter
Strokin05's Avatar
Alright guys that did not fix it... How do you tell if the steering box is bad? And how big of a PITA is it to swap out?
Thank you,
Mike
post #9 of 28 (permalink) Old 08-15-2009, 01:28 PM
105vegas's Avatar
did you check the ball joints ? are you showing any odd tire wear ?
05 f250 cc
RCD egr delete, SCT with RCD tunes
03 turbo
magana flow 4" no muff
105vegas is offline
post #10 of 28 (permalink) Old 08-15-2009, 01:33 PM Thread Starter
Strokin05's Avatar
I did check the ball joints, surprisingly the yare still good.. I did not look at tire wear but I will check that out. Also now the steering wheel is off even more to the right then origianlly when I bought the truck
Steering? teamsween21 Duramax 2001-2004 (LB7) 5 07-13-2009 08:13 PM
Steering Box!!!!! Big Bad Stroker 1994-2003 7.3L Power Stroke 1 08-01-2007 02:33 AM
ORU Steering! Big Bad Stroker 1994-2003 7.3L Power Stroke 5 04-11-2007 12:40 AM
obs steering box ford_truck_1976 1994-2003 7.3L Power Stroke 10 11-27-2006 04:19 AM
Steering & Steering Pumps sredish 2003-2007 6.0L Power Stroke 7 10-10-2006 01:48 AM
