Manual v electric transfer case - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robert S., this thread has received 12 replies and been viewed 3701 times.
post #1 of 13 (permalink) Old 08-14-2009, 06:36 AM Thread Starter
Never owned a 4x4 before and I'm looking at a 2006 F-250 that has a manual 4x4 transfer case. Other than the obtrusive stick in the floorboard, what are the pros and cons of each?
2006 F-150 SuperCrew
Currently looking for first diesel truck.
Robert S. is offline
post #2 of 13 (permalink) Old 08-14-2009, 02:00 PM
UpstateDieselGuy's Avatar
I prefer Manual Transfer Cases as there are no electrical/vacuum connections/systems to worry about. Lock the Hubs, Pull the Lever, and Go! P.S. you can shift on the fly with a manual transfer case as long as the hubs are locked and there are no tires spinning. Chris
SOLD
UpstateDieselGuy is offline
post #3 of 13 (permalink) Old 08-14-2009, 03:19 PM Thread Starter
Thanks, because I found two nearly identical trucks, one w/shift on the fly and the other w/manual is $4k less! Mileage difference between them is less than 10k.
post #4 of 13 (permalink) Old 08-14-2009, 03:27 PM
Banned
Go with the manual the electronics sucks... Mine has never not worked. But every time it just seems like a crap shoot... When I say the electronics suck I include all manufactures.
wastedwagesracing is offline
post #5 of 13 (permalink) Old 08-14-2009, 08:35 PM
No problem. The simpler, the better I sometimes which I had a standard transmission, that is until I plow Chris
SOLD
post #6 of 13 (permalink) Old 08-14-2009, 09:42 PM
fuzzys69's Avatar
I hate the elecric one, if i buy a new truck i hope i can find one with a manual in it.
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #7 of 13 (permalink) Old 08-15-2009, 12:05 AM
SSpeeDEMONSS's Avatar
i have the electric in my ford right now but when i do the swap the manual from the dodge is going in.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #8 of 13 (permalink) Old 08-15-2009, 12:08 AM
********* and Mafia #90
Bcarriveau's Avatar
I love my electric one I can tell you i use it ALOT in the winter, 4x4 to 4x2 all the time.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #9 of 13 (permalink) Old 08-15-2009, 01:13 AM
I can count to Potatoe
I love my manual i go from4x4 to 4x2 all the time as well. I just drive with the front hubs locked when I think I might need 4x4 and just reach down pull the lever and all is well!
dayusex is offline
post #10 of 13 (permalink) Old 08-15-2009, 01:17 AM
Bcarriveau's Avatar
can you do it on the fly as well? say going 40mph, let off the throttle and let it lock in ? is so that is sweet that the manual ones will do that as well.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Transfer case electric silenoid Robts 5.9L Cummins (2003-2007.5) 1 02-18-2009 10:22 PM
transfer case cummins-dodge Whats Been Sold 1 02-05-2009 10:19 PM
Transfer case cummins kid 5.9L Cummins 12 Valve (1994-1998.5) 5 01-14-2008 11:45 PM
electric to manual t-case bluovaltruk01 General Ford Truck and Excursion 7 12-08-2007 01:29 AM
241 transfer case dld buckeyestroker General Dodge Discussion 5 06-04-2007 08:52 PM
