F-150 Gas'r Question.. Headgasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OverPressured, this thread has received 5 replies and been viewed 659 times.
post #1 of 6 (permalink) Old 08-19-2009, 07:21 PM Thread Starter
Hey guys, Its not a diesel but I have a bit of an issue with a relatives 05 F150 5.4 triton v8. He was driving it down the road and it just shut off on him. Towed it home, When we tried to start it it seemed like 6cyliners were firing.. it had a miss to it and wouldnt start at all. So we looked and found the headgasket was blown. These things have alot of electronics.. would it have shut off electricly? Or do you think theres internal damage. We were told it was going to cost around $900 dollars to have a gasket installed. But It seems pretty high to me. I am thinking about doing a compression test on all 8 cylinders, if they test fine just slap a new head gasket on and see how it runs. Is that a good idea or bad? Anyone had this happen to them or know anything about the 5.4's? Any help in appriciated! Thank you!
OverPressured is offline
post #2 of 6 (permalink) Old 08-19-2009, 09:35 PM
vcassens's Avatar
what ever you do change the spark plugs while you have the heads off and put the best plugs in it possible they are not fun when they break off which most do in the 5.4 triton also check the camshafts and lifters while in ther I worked on one that the lifter went bad at 60,000 miles so good luck
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #3 of 6 (permalink) Old 08-20-2009, 03:46 AM Thread Starter
Thanks for the info. Theres a tapping noise when the truck ran fine before the headgasket blow, do you think that could be the lifters? I thought maybe valves but we were told that the valves in that truck are self adjusting, and it made that tapping noise since he bought it at 20,000 miles. It now has 81,000
post #4 of 6 (permalink) Old 08-21-2009, 06:28 AM
4play's Avatar
ok, the head gaskets are not known for failures, also the spark plugs like mentioned before "can" break if you dont know the procedure to remove them. even if they do break its not a big deal to remove them with the proper tools. now that you mentioned noise i would have to assume its probably the cam phasers mainly the pass side. for it to shut off i would say its not a gasket or phaser problem. the pass side cam phaser is notorius for a knock/tap type noise and is fixed by replacing the phaser.
i have seen coils cause misfires and even a shut down concern. you will need to identify which cylinder(s) are misfiring if its a coil concern. and i would look into a coil concern first and correct that first.
4play is offline
post #5 of 6 (permalink) Old 08-23-2009, 07:36 PM
Mod Friendly Title
Zaairman's Avatar
I'd look into a leaky injector. The 05s are known for it. Ford even provided a longer warranty to cover em.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #6 of 6 (permalink) Old 08-26-2009, 04:17 AM Thread Starter
Thanks for the info guys, going to check into it.
8.3 Cummins Headgasket acesneights1 Medium and Heavy Duty 3 02-21-2009 03:49 AM
Blown Headgasket????WTH danster 2003-2007 6.0L Power Stroke 11 02-13-2009 12:53 AM
headgasket job need help!!! 04-F350 2003-2007 6.0L Power Stroke 4 04-25-2007 02:08 AM
puking always means headgasket? ncbowhunter 2003-2007 6.0L Power Stroke 18 03-13-2007 10:49 PM
hypermax headgasket?/Puking tedshields 2003-2007 6.0L Power Stroke 20 08-14-2005 05:43 PM
