Factory Fog Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TowRig, this thread has received 1 replies and been viewed 402 times.
post #1 of 2 (permalink) Old 08-22-2009, 10:10 PM Thread Starter
Send a message via AIM to TowRig
Factory Fog Light
How do you change the bulbs in the factor fog lights? 2000 Ford F250 SuperDuty
Do I have to replace the whole damn light?
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #2 of 2 (permalink) Old 08-23-2009, 07:28 PM
Super04Duty's Avatar
Its a little bit of a pain. There are little screws on the back side of the housing that keeps the bulb from turning if theyre tight. What I Did, was remove my license plate and bracket, and pull my grill out. Then I had room to look in there and use a wrench to remove the whole fog light housing. Then I could see the screws and unscrew them.
It sounds like more work than it is. Its a pain, but not terrible. Took me about 20min.
-brian
'04 F-350; CC, LB, SRW
'00 Dodge Neon; AutoX car
'04 VW Touareg; Her car
'57 Chevy Truck; 3200, life long project extraordinaire, 11 years and counting
'47 Dodge 1.5-ton, Cummins swap canidate
Singles Club Member #70
Super04Duty is offline
tow haul light flashing trans temp pegging andcheck guage light comes on powermad 2003-2007 6.0L Power Stroke 12 05-16-2010 11:34 PM
Fog light/auto head light mod? Carssuck Chevy - Modification instructions, Product installs and Tech Articles 14 03-20-2008 08:14 AM
wtb factory fog light assemblies w/wiring Hoss350 Whats Been Sold 7 02-11-2008 03:05 AM
ABS Light & Brake Light worm drowner 1994-2003 7.3L Power Stroke 4 10-23-2007 08:07 PM
Door Ajar light wont go off nor will the dome light?? imported_99powerstroke 1994-2003 7.3L Power Stroke 10 03-14-2007 04:13 AM
