Dynatrac diff cover installed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jvencius, this thread has received 6 replies and been viewed 507 times.
post #1 of 7 (permalink) Old 08-26-2009, 09:23 PM Thread Starter
I finally got my Dynatrac front differential cover installed today and IMO it's pretty spiffy. Normally a diff cover isnt' anything you'd think much about but since I was going to take my old cover off for this service interval I figured I might as well put something on that's improved over stock. Overall it was a pretty simple job but I did have to grind a tiny bit out of the edge to clear the inner u-bolt on the driver's side spring pack and that held me up a bit since I never bought a new Dremel tool after smoking my old one (literally, it was screaming hot and smoke was coming out of it) and had to wait for Mrs. JV to come home from work and drive me to Home Depot for a new one. Once I got the edge ground out the cover went right on and I refilled the diff with some Redline 75W90.
Like all the Dynatrac parts I've seen (I have their Free-Spin hub conversion kit) it seems to be very high quality and should hold up a good long time so I'm pleased. On a side note--I used 3 quarts plus a tiny little bit of fluid (spilling a couple tablespoons in the process) so that should be the correct amount of fluid, right? The owner's manual says 2.7 liters and 3 quarts plus a smidge is right around that amount, if I've done my arithmetic correctly.
Here's a shot of how much I had to grind off the edge of the cover:
Here's a crappy cellphone pic of the cover installed--my truck only has a leveling kit for the front suspension and I didn't need to re-clock the front axle so the tie rod runs right across the center of the cover.
jvencius is offline
post #2 of 7 (permalink) Old 08-26-2009, 09:32 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
If you ask me 75w90 is to light even if it is the front. It does look nice though.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #3 of 7 (permalink) Old 08-26-2009, 09:35 PM
BillsFan's Avatar
Looks good!
It sucks you had to grind off material, hopefully that doesnt cause a problem down the road.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #4 of 7 (permalink) Old 08-26-2009, 09:39 PM Thread Starter
Bill
Lemme guess--you'd recommend something heavier from Amsoil?
jvencius is offline
post #5 of 7 (permalink) Old 08-26-2009, 09:48 PM
I would recommend heaver oil no mater what oil you buy. Of course Amsoil is my preference.
Bill
5" SS Tip
post #6 of 7 (permalink) Old 08-26-2009, 10:07 PM
Dang John that looks TRICK man. Very nice
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #7 of 7 (permalink) Old 08-26-2009, 10:42 PM
Another day in paradise
nevrknow's Avatar
Looks sweet. Have a SOLID AXLE cover coming Friday I hope. $81 including shipping. How much was that one?
2002 f250 4x4 SRW, 7.3L Auto, 4" exhaust, 20" rims on Toyo MT's, Boost, Pyro, Tranny ISSPRO ev's underdash pod., DP TUNER F5, stock, 60 tow, 80 , 120 race, DYI Tymar Intake
2000 New Holland 3930 Diesel tractor
nevrknow is offline
Dynatrac Pro-Rock cover quote? jvencius Supporting Vendors Forum 1 06-25-2009 02:36 PM
Dynatrac Pro-Rock cover on a front D60 fit? jvencius General Ford Truck and Excursion 0 06-25-2009 12:17 AM
08 and up diff cover... F2million 2003-2007 6.0L Power Stroke 4 06-11-2009 01:50 PM
Detroit Trutrac, Dynatrac diff cover, DJ's Fuel intensifier.. All new in box nummit Whats Been Sold 3 01-24-2009 05:36 PM
Sterling Diff Cover (Bluetorch Kryptonite Cover) tunedportcj5 Whats Been Sold 1 04-05-2006 01:06 AM
