Does size matter?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by truckerstyle04, this thread has received 4 replies and been viewed 528 times.
post #1 of 5 (permalink) Old 01-17-2006, 02:00 AM Thread Starter
Does size matter??
Is there that big of a difference in quarter mile times between like a 250 or 350 or lets say a crewcab compared to extented cab? Buddy has a crewcab long bed 350 4x4 with a filter and keeps saying he will smoke me? Can he? I'm not sure if its just like a drop in or an actual intake?? but I know thats all he has.
truckerstyle04 is offline
post #2 of 5 (permalink) Old 01-17-2006, 02:06 AM
Nah....launch in 4HI and make him wonder what you did to your truck to beat him so bad.
Unbroken is offline
post #3 of 5 (permalink) Old 01-17-2006, 02:18 AM
F250/350 makes no noticeable difference,were talking within lbs of each other,its the drive(4x4),2wd,configuration,and single/dual wheels that does. His crew cab is probably 2-300 lbs heavier than your excab.His long box is another 150lbs+.You probably are 500 lbs lighter than him,provided he is srw,if hes dually theres another 250lbs.If he isnt lieing you will smoke him,he may be leing and have a tuner installed, in which case he will smoke you pretty easily.
John DiMartino is offline
post #4 of 5 (permalink) Old 01-17-2006, 02:44 AM
If he smokes you real bad come on over and get Stroked Lightning and then smoke him : : :
GENE
GENE
99 F450 CC, AT, XLT LB Shortened Frame 3.5 , John Wood Tranny & TC , H2 Turbo , DI 6 Pos Custom Chip , Mini-me's , Custom Intake , Idle Speed Control, Turbo Temp Monitor , 4 Down Pipe, 5 Exhaust , Isspro Gauges , Power Pedal Mod. Fuel Regulator System , Dual Stock Fuel Tanks. White Ext , Grey Int , Alcoa 19.5 Rims Factory Center Caps , Cowl Induction Hood , Dual Highway Products Tool Boxes , 5th , Wheel, Goose Neck, Pintle & Class 5 Hitches.
Builder and Driver of Stroked Lightning 11.519 @ 119.26 mph
Builder and Driver of Blue Thunder
Weweld is offline
post #5 of 5 (permalink) Old 01-17-2006, 12:12 PM Thread Starter
Might have to let him win if thats the case hahaha!!!
