5.4L F150 missing, please help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WasGas, this thread has received 5 replies and been viewed 1369 times.
post #1 of 6 (permalink) Old 09-07-2009, 02:38 AM Thread Starter
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
Yesterday my dad was driving down a muddy road in the rain, shortly after that the engine started missing and his check engine ligth came on and would flash sparadicaly. He took it into an autozone and their scanner told him that it had a bad #6 coil or plug. He went to change both and found that the engine was very muddy so he completely sprayed out the plug housing with air before removing it. Once replaced the engine ran fine for a minute and then started doing the same thing, then there was also a ticking sound from the engine that sounded like a bad lifter would. He then pulled the plug again thinking maybe there was debris in the cylinder, inserted a rubber hose into the plug threads and cranked it but no debris came out, just fuel.
The noise was not present until the plug was changed.
Check engine light was solid but is now sparatic.
2005 F150 3V 5.4L
WasGas is offline
post #2 of 6 (permalink) Old 09-07-2009, 07:16 PM
Bigking's Avatar
I use to have a V10 Excursion that was doing the same. The ticking in mine was gthe spark going into the block. Before I could fix it the engine spit the plug and ignitor off the block. Cracked the ingitor in half. Replaced the ignitor and plug and drove just fine.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #3 of 6 (permalink) Old 09-07-2009, 10:57 PM
4play's Avatar
a flashing light means a misfire is occuring, and after awhile the light will become solid. either light condition will set a code. what i would do first is re-check the codes, and see what cylinder it is. its possible that water might be in the other plug holes.
be carefull removing spark plugs in these as they are prone to break. i also assume he used a 9/16" plug socket. i have seen people break plugs during installation. also nickle type anti-seize should be used on the metal jacket part of the ground electrode.
one more thing, the 3v's have known problems with the variable cam timing phasers which will sound like a lifter and its usually bank-1 rh side.
4play is offline
post #4 of 6 (permalink) Old 09-08-2009, 09:04 PM
Yep i work at a small ford dealer and do atleast 4 phaser jobs a month. Unplug the connector on top of the valve cover on the suspected side that is knocking while running. If noise goes away when the plug is disconnected i would suggest replacing phaser. I have also seen problems with selnoid body gaskets that control oil flow to the phaser. Just a heads up. How much fuel is coming out also? Mabey a stuck injector.
Alex
03 f250 FX4 55,000 miles
-stock
99 F-350 4x4 CC LB 250,000 miles
-leveled w/ 315-75-16's
-4'' dp to 5'' stack
-CAI
-bullydog 6 pos
-D66 turbo
Stroked383 is offline
post #5 of 6 (permalink) Old 09-15-2009, 12:58 AM Thread Starter
WasGas's Avatar
Well my dad ended up taking it to Ford and found out that the injector stuck open, and filled the cylinder with gas, then the rod bent.
They said they will cover it and replace with a shortblock, will this be an OEM block, or a reman?
1FLPW14515KB59985
WasGas is offline
post #6 of 6 (permalink) Old 09-16-2009, 09:03 PM
4play's Avatar
it will be a ford reman.
4play is offline
Cow VS. F150 pontiacross The Parking Lot 13 12-31-2008 07:39 PM
98 f150 Bcarriveau The Parking Lot 4 11-08-2007 06:05 AM
06 f150 mxchase General Gas Vehicle 0 08-21-2007 11:11 PM
I just saw an 07 F150 HD... imported_LiftedBlackHD General Ford Truck and Excursion 3 06-17-2007 05:00 AM
F150 HD Update SeeYa General Gas Vehicle 21 05-10-2006 08:52 PM
