Dynatrac Free Spin Install - What else while there? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6_Myles, this thread has received 19 replies and been viewed 3001 times.
post #1 of 20 (permalink) Old 09-09-2009, 12:45 AM Thread Starter
I be Architect'n
I'm installing my new Free spin kit on my Excursion and had planned on replacing these items also:
New Spicer U-Joints
New Dynatrac Ball Joints
New Tie Rods and Drag link bars
What else should I do while I'm there? Thanks
Myles
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #2 of 20 (permalink) Old 09-09-2009, 01:01 AM
Haulin' Hay
NCfarmboy's Avatar
Well, I just wanted to say that I'm jealous over the kit... Post up some pictures and impressions of the kit if you can. It looks nice!
NCfarmboy is offline
post #3 of 20 (permalink) Old 09-09-2009, 01:15 AM Thread Starter
I be Architect'n
Thanks. For what it costs is should be more than nice, it should be freakin spectacular!
J/k the kit is VERY impressive in is size, simplicity and quality. I've got 140k miles on the rig now and figured a bearing failure was coming much sooner than later so I pulled the trigger. I did a cost analysis on the kit vs. replacing the unit bearing hub and the cost was equal if a failure happened anywhere other than close to home. I spend alot of time of the road with the family so it made sense to me.
6_Myles is offline
The Following User Says Thank You to 6_Myles For this addition to TDG:
NCfarmboy (09-12-2009)
post #4 of 20 (permalink) Old 09-09-2009, 02:53 AM
I can't think of anything else that would need replacing that isn't on your list already. I went with Moog ball joints, but other than that, your list looks good. I would recommend buying new hub mounting studs and nuts since they're cheap (IIRC <$25 for enough to do both sides) since trying to re-use the stock pieces just isn't worth it if they're rusted in place.
Here's the article I wrote about installing my Dynatrac kit--maybe it'll help.
jvencius is offline
post #5 of 20 (permalink) Old 09-12-2009, 04:20 PM
Haulin' Hay
NCfarmboy's Avatar
That makes sense... Justification for me right there as well.
post #6 of 20 (permalink) Old 09-12-2009, 04:23 PM
bushpilot's Avatar
i would replace the 4x4 yellow o-rings, axle tube dust seal & the hub vac. seal...not
replacing these items is ASKING for trouble.
and you might as well do the ball joints <if you havent done 'em already>
Don R.
Truck Audio,
bushpilot is offline
post #7 of 20 (permalink) Old 09-12-2009, 04:34 PM
The yellow o-rings and hub vacuum seals aren't necessary with the Dynatrac kit--it eliminates them since the kit converts to manual Warn lockouts. In his 1st post, the OP did say he has new ball joints and tierod ends, so that's sensible.
jvencius is offline
post #8 of 20 (permalink) Old 09-12-2009, 04:35 PM
bushpilot's Avatar
Originally Posted by jvencius View Post
The yellow o-rings and hub vacuum seals aren't necessary with the Dynatrac kit--it eliminates them since the kit uses manual Warn lockouts. In his 1st post, the OP did say he has new ball joints and tierod ends, so that's sensible.
oh...and YUK !
Don R.
Truck Audio,
post #9 of 20 (permalink) Old 09-12-2009, 04:38 PM
oh...and YUK !
It took every bit of self-restraint I had not to write "The OP already has new BJ's..." but I couldn't help myself any longer...
jvencius is offline
post #10 of 20 (permalink) Old 09-12-2009, 04:47 PM
bushpilot's Avatar
i can see the benefit of the dynatrac bearings...but i dont see the point
of giving up ESOF hubs...ive got 85k on mine and ive NEVER had a problem
w/ them locking or unlocking when "requested".
the worst problem ive ever had w/ the hubs is torque binding when unlocking...but
a quick blip of the throttle or stab of the breaks unbinds 'em
i dont like the idea of having to get out in the mud/rain or SNOW to lock hubs
Don R.
Truck Audio,
4X4 question / dynatrac free spin 01dezoll 5.9L Cummins (2003-2007.5) 5 04-04-2008 07:45 AM
Dynatrac Free Spin information cmoschip General Dodge Discussion 1 01-01-2008 09:07 PM
Anyone done the Dynatrac Spin Doctor Free Spin Hub Kit NMU98 General Ford Truck and Excursion 2 08-09-2007 01:21 PM
Dynatrac Releases Free Spin Kit for 05+ Superduty DrSpeed General Ford Truck and Excursion 4 12-03-2006 02:20 AM
Group Buy Dynatrac Free-Spin Hub Conversions LIPD Supporting Vendors Forum 83 04-21-2006 01:34 AM
