e locker yet??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by F2million, this thread has received 19 replies and been viewed 1403 times.
post #1 of 20 (permalink) Old 09-13-2009, 06:21 PM Thread Starter
Rollin' Coal
F2million's Avatar
e locker yet???
is there a e locker out for our trucks yet? im tireed of getting stuck and having my step dads dmax pull me out.
2010 F250 INGOT SILVER
Stock for now, but not for long
SOLD 06 F250
2.5" donahoe lift, 20x10 procomp wheels, 35/12.50/R20 Toyo Open Country M/T tires,
SCT by Vivian, mbrp ss down pipe, cat delete, silverline 4" exhaust, Dfuser coolant filter, RCD EGR delete, zoodad mod, AFE Stage 2, Spearco intercooler, ARP headstuds, AMSoil bypass oil filter, 5w40 AMSoil, DiPricol guages, Hid lights, Pioneer Z2 Navi, PAC backup camera, JL 250 amp, JL stealth box 10" sub.
Elite Diesels
F2million is offline
post #2 of 20 (permalink) Old 09-13-2009, 08:20 PM
I can count to Potatoe
you can always get an ARB air locker? Where are you getting stuck in 4wd where a chevy 4wd can pull you out, usually its the otherway around.
dayusex is offline
post #3 of 20 (permalink) Old 09-13-2009, 10:18 PM Thread Starter
Rollin' Coal
F2million's Avatar
only 1 front tire and one back tire spins. i dont really care for the air locker because of the compressor and leaking air lines ect...
SOLD 06 F250
Elite Diesels
post #4 of 20 (permalink) Old 09-14-2009, 01:06 AM
If you get a big enough compressor/tank you can use that air for more than just a locker (horns, airing up tires, tools, etc...). Sure, air lines can leak but so wires can break and I'd much rather try to diagnose a leaky air system than start stabbing wires to troubleshoot a faulty electrical doodad.
jvencius is offline
post #5 of 20 (permalink) Old 09-14-2009, 02:03 AM Thread Starter
Rollin' Coal
F2million's Avatar
how many psi and how fast do the compressors pump up?
SOLD 06 F250
Elite Diesels
post #6 of 20 (permalink) Old 09-14-2009, 02:32 AM
lilpooh's Avatar
depends on the size of the compressor-cfm
2004 F350 CC DRW King Ranch
lilpooh is offline
bushpilot (09-14-2009)
post #7 of 20 (permalink) Old 09-14-2009, 02:37 AM
bushpilot's Avatar
the factory offers an elocker now...buy it and have it installed
Don R.
Truck Audio,
bushpilot is offline
post #8 of 20 (permalink) Old 09-14-2009, 07:55 PM Thread Starter
Rollin' Coal
F2million's Avatar
you pay for it.
SOLD 06 F250
Elite Diesels
post #9 of 20 (permalink) Old 09-14-2009, 08:55 PM
SSpeeDEMONSS's Avatar
where are you getting stuck? give me a call, ill come pull you out.
just get a true-trac or a detroit.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #10 of 20 (permalink) Old 09-14-2009, 09:25 PM
bushpilot's Avatar
you pay for it.
youre the one that keeps getting STUCK
Don R.
Truck Audio,
Locker or LS??? CSIPSD Supporting Vendors Forum 1 03-12-2009 08:21 PM
Do i have a locker? Okie 5.9L Cummins (2003-2007.5) 13 05-02-2008 06:51 PM
Locker for 11.5 aam? imported_06Cummins4x4 Supporting Vendors Forum 1 01-16-2008 03:10 PM
locker fuzzys69 Drag Racing 3 07-19-2007 12:06 AM
Add A Locker To The Rear? bigdraft General Ford Truck and Excursion 9 03-31-2006 12:34 AM
