Door Seal mod - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by EJ Krueger, this thread has received 5 replies and been viewed 841 times.
post #1 of 6 (permalink) Old 09-17-2009, 02:34 AM Thread Starter
Door Seal mod
I just did this mod today and i can hardly close my door with 95 degree weather, dont even want to think about how hard it will be when it gets down to 40 and the 3/8 OD - 1/4 ID vinyl tubing doesnt give as much. To the other members how hard do you have to slam your doors? On a scale of one to ten and ten being using all of my power to slam the door I would say its at about a 7.5
EJ Krueger is offline
post #2 of 6 (permalink) Old 09-17-2009, 03:23 AM
plainredtruck's Avatar
Images: 11
It's no harder to close my doors, but I have developed a leak when it rains - drips right onto my elbow on the door panel.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 6 (permalink) Old 09-17-2009, 04:52 AM
bushpilot's Avatar
w/ the poly tubing it takes time to get used to, you cant reduce the wind
and road noise w/OUT sealing the door tight ! most of the wind noise comes
from the front angle/seal portion of the door.
one secret ive learned is when you close the door dont just SWING it and let
go...pull it and keep a firm pull on it, or it will "bounce" against the seal and
fail to close all the way.
I rarely have to close my door more than once. passengers have a tough time,
youll find, if you crack your window the passenger will have a much easier time
of closing the door the 1st time.
I would NOT recommend using foam backer "round"/cord...it wont keep the seal.
Give it a few days, youll get used to it...and youll appreciate the significantly reduced
wind noise <at highway speeds>
Don R.
Truck Audio,
bushpilot is offline
post #4 of 6 (permalink) Old 09-17-2009, 05:57 PM
The DUDE!!
sprman's Avatar
Hey don,
this is something else we can do while waiting on my tires...
we got a long list of stuff to do tomorrow!!
2005 F-250 CC FX4 - bought it, changed some stuff
Eighty Sixed member - #3
Ridin' Dirty - #26
"All the oil is in TEXAS, but the dipsticks are in DC"
"If Obama is the answer, it must have been a stupid a** question......"
sprman is offline
post #5 of 6 (permalink) Old 09-18-2009, 03:02 AM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
what yall got going on tomorrow. I see how it is..... no invite for me
to the op I am looking in to doing this mod my self give it a few days and see if it becomes easier and post back. I sure don't want to have to slam the heck out of my door like i was trying to break my window all the time
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #6 of 6 (permalink) Old 09-18-2009, 03:07 AM
********* and Mafia #90
Bcarriveau's Avatar
prt
I think they make pills for this
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
Door seal mod rdr99 Ford - Modification instructions, Product installs and Tech Articles 11 06-02-2009 06:54 PM
Door Seal mod???? Superstroker General Ford Truck and Excursion 18 05-29-2009 04:46 AM
'Door Ajar' lamp staying on w/ door closed??? BlownGreenGP General Ford Truck and Excursion 4 02-03-2008 04:22 AM
Door/seatbelt dinger and door seal mod...awesome... John_DeereGreen 1994-2003 7.3L Power Stroke 18 12-24-2007 09:15 PM
Garage Door Opener Compartment Door iwejan Whats Been Sold 2 05-04-2006 12:09 PM
