99 f350 bad engine value - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by INT_MAN, this thread has received 2 replies and been viewed 1348 times.
post #1 of 3 (permalink) Old 09-18-2009, 06:02 PM Thread Starter
I have the opportunity to buy a 1999 f350 dually lariat 4x4 with about 220k on the clock, trans was recently replaced, and the engine has a knock , but still runs. the truck is definitely worth repairing, I am curious as to what you guys think I should pay? how much is too much?
INT_MAN is offline
post #2 of 3 (permalink) Old 09-19-2009, 12:58 PM
rock removal technition
this one went for 3
https://www.thedieselgarage.com/forum...ad.php?t=80867
had to
completely gutted the interior and cleaned, put new seats in, new carpet in. rear springs, u joiunt , yoke, new brakes and cut rotors, still need door and dually fender repaird.
double-s-diesel is offline
post #3 of 3 (permalink) Old 09-19-2009, 01:47 PM
harry6.0's Avatar
A knock, especially from the lower end of the motor can easily result in a complete motor rebuild or replace. I would factor that into your estimate. Remember, always start out low on an offer and have a preset limit in your mind. I would start an offer of 3k and no more than 4k. A good clean used 99' dually with only around a 100k miles average about $14-16k. You could easily end up with a 10k repair bill in parts and labor, unless you do it yourself. Harry
harry6.0 is offline
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
Engine Hours on 2007 F350 07 350 NWGMonst 2003-2007 6.0L Power Stroke 14 01-24-2008 08:48 PM
Possible to measure engine deck specs on engine in truck? Trulyvintage 7.3L and 6.9 IDI (Pre 1994) 3 06-16-2007 04:10 AM
f350 with a cat c7 troyerdiesel Diesel Conversion 4 02-25-2007 11:54 PM
04 f350 pulling a 04 f350 PSTROKER 2003-2007 6.0L Power Stroke 22 06-27-2006 04:32 PM
