Brake Tab thing hitting rotor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brendonv, this thread has received 2 replies and been viewed 666 times.
post #1 of 3 (permalink) Old 09-24-2009, 09:48 PM Thread Starter
brendonv's Avatar
I have new rotors, calipers, and Fords pads on my truck.
It is squeaking and putting a small grove in the rotor. I checked it out and it's one of the four silver tabs that hold the pad tight into the grove. I took it apart twice, even switched sides, and bent it straight to sit more flush.
Still squeaking.
I bled the brakes twice, and lubes the slide pins.
Any ideas?
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #2 of 3 (permalink) Old 09-25-2009, 02:19 AM
plainredtruck's Avatar
Images: 11
Still squeaking.
Any ideas?
Is yours an early '99 or a late '99, because I think there's a difference between them. If not in the '99 model year, then a little later.
My guess is you got the wrong part #'s for your truck.
Did you compare the replacements with the ones removed?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 3 (permalink) Old 09-25-2009, 10:13 AM Thread Starter
brendonv's Avatar
It's an early. There is no difference between calipers and pads, just rotors and hub bearings. Which the truck now wears late model bearings and rotors.
brendonv is offline
Brake rotor noises? Horsehaulin Medium and Heavy Duty 12 04-08-2009 05:27 AM
Front brake rotor questions 99fordtruckguy 1994-2003 7.3L Power Stroke 3 02-11-2008 03:50 AM
Superduty brake rotor size? jvencius General Ford Truck and Excursion 2 01-10-2008 07:07 AM
2005 5.9 not hitting on all 6 John Franklin 5.9L Cummins (2003-2007.5) 0 10-08-2007 04:24 PM
Rotor and brake pad replacement rum4 General Ford Truck and Excursion 9 08-25-2006 01:32 PM
